Old 09-06-2017, 08:43 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
P/Ns to fix oil leaks required
I have had a number of small oil leaks coming from my car for approx 20 years, but have noticed lately they seen to be getting worse - 4 to 6 drops a day.
I have the following leaks -
Front of engine, suspect oil pump.
Output shaft area of gearbox.
Join between the engine and gearbox - unsure till I take it apart.
(while apart should I replace the flex-plate, I remember seeing somewhere that there is a stronger version - thicker).
What I require are part numbers for the various seals or o-rings and flex-plate.
TIA
Old 09-12-2017, 07:45 PM
SURTEESS's Avatar
Re: P/Ns to fix oil leaks required
Forget about the earlier message - I think Wingers Subaru here on the North Shore in Auckland were telling me load of porkies!!
found the leak(s) from both engine sump and the gearbox sump + 1 in-hex allen bolt at lower front of engine.
In-hex bolts all now done up to 35 Nm
Engine sump 10 out of 12 bolts done up to 12 Nm (other 2 will need to be done while on hoist).
Gearbox sump 8 out of 16 bolts done up to 12 NM (the rest I should have looked at when car was all in the air - so another hoist job)
But best news of all - I picked up a working headlight washer pump - from 1991 suzuki escudo - picture attached, filled it with WD40 for an hour and away she went, just have to modify the 2 pin round connector (leaving it in place and adding a rectangular 2-pin to match the SVX loom).
Better to pay NZ$27 from Pick A Part than over NZ$140 for the same thing from Wingers.
It is going to be a great week - ......
