#196
I ordered the valves today.
#197
uhmmm... Was I included?? I can call and pay you at any time.
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
#198
305-546-9359
Payment
Just sent you a payment. Hope I'm not too late.
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
#200
you're in on it
I'm in!
Great. I'll try to get on removing the cams here soon. Let me know when you can't wait any longer, and I'll try to get them out without removing the motor.
#202
and looky what I got today. Here are some pictures of the first set of cams ground...the prototypes if you will. Sorry, not cleaning off the packing grease for pictures--deal with it.
complete set of boxed cams intake cams Here's a picture of the base circle of the 1st lobe on the intake cam. This is where the camshaft is thickest. What I'm trying to show in this picture is how the base circle on our cams does not cut into the shaft. This illustrates how our valve set up maximizes lift before coil bind without degrading the strength of the cams. close up of intake lobes illustrating fillets (radius in castings up to sides of lobes) not cut into. exhaust cams exhaust cam 1st lobe showing shaft is not cut into close up of exhaust lobes illustrating fillets not cut into So there you go...good, clean, exactly right performance cams with state of the art profiles. |
#203
Pictures!
Awesome. Thanks for the pix. It will be great to see how these perform for you. It will also be very interesting to see improvements for the N/A guys as well.
#204
I won't be putting my cams in until I have the rest of the parts to build my engine which will be very far from naturally aspirated. The only NA guy to order the cams so far is OBI who is also changing pistons and who's engine is in a porsche.
#206
Compression ratio
#207
are we going as low as 8.5:1??? I thought it was going to end up closer to 9... lower is better for more boost Mike... have any idea where our rods and pistons are?? I would love to get my bottom end put together so the people who want me to build theirs can get their costs figured out
Tom |
#208
#209
EG33 Turbo Porsche 914 |
#210
I'll call and check.
