Old 02-13-2008, 10:33 PM
danyvaly danyvaly is offline
engine unresponsive initially
hi
the engine hesitates or it is unresponsive when is cold. it starts strong but when i press the accelerator pedal it stays unresponsive but then, seconds later it accelarates normally. few minutes later the engine is fine. the engine light is on indicating left knocking sensor... could this be the problem
Old 02-13-2008, 11:14 PM
Trevor's Avatar
Trevor Trevor is offline
Originally Posted by danyvaly View Post
hi
It could well be. You are reporting an intermittent fault which is always difficult to be sure about.
The knock sensors a capable of retarding the ignition timing as is their normal function. This could be happening excessively at start up, to then come right. As a first option check the connections to the left knock sensor.
Trevor, New Zealand.
Old 02-13-2008, 11:21 PM
Trevor is right. If the sensor is bad or even better, disconnected, the ECU runs on a "limp" Map in which timing is significantly reduced due to the inability to monitor knock. It will also put a hurting on your fuel economy
