Campaign filter replacement
Is there a place I can get a cheap campaign filter replacement (I put the campaign filter kit on my 1995 SVX because it sounded like a good idea.) I've had a major fluid service (from synthetic/dexron mix to dexron in 11/02) and now will add AT oil cooler, so think it would be good to replace (even tho they said I never really had to replace it (?)
I could have gotten filter from dealer two years ago. Don't know if that's the place to get one now (whole kit was about $25 from the dealer two years ago). Please let me know. THANKS!
If you search you will find two different filter kits, one for the SVX and one for a Legacy, both have the same filter, both are inexpensive. You are allowed only one SVX filter kit and have to give your VIN to get it, unless you know the dealer real well.
