Old 11-06-2005, 12:38 PM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Anyone know how to pull a CE code on a 90 Legacy?
Please Please Please.
Old 11-06-2005, 05:58 PM
Maybe
Elinoalex
The Haynes manual I have says you need to disconnect the Test Mode Connector, and turn the ignition ON. [but don't start the engine] Then you count the blinking of the CE light, the usual way.
To get at it, you need to take off the panel facing the driver's knees. There are two screws to remove, then the panel is only held on with 3 clips on the top edge. Pull panel downwards.
I can't remember the colour of the connector, or the wire, but it's easy to find. It only has one wire to and from. The connector itself is spade terminal [or screwdriver blade] broad at the bottom, then steps in narrow at the top. Pull this apart, turn on the ignition, your CE should blink the codes.
PS, when you get the codes, I can give you what they mean.
Old 11-06-2005, 11:37 PM
THAWA
THat's not right. You need to connect the two black connectors under the dash, then turn the key on and read the code. It's like 6-8 screws to get that panel off, but once you know where to look you can do it without removing the panel at all. Only takes me a minute or two to check codes nowadays.
Old 11-07-2005, 02:29 AM
My '95 is JDM, and the method above is correct for JDM and UK models as outlined.
If the US version for OBD 1 is different, I'm sorry for the misinformation. We have had many long threads about [OBD] diagnostics, and they seem to be un-necessarily complex between different markets.
Old 11-07-2005, 03:17 PM
elninoalex's Avatar
Registered Abuser
Thanks guys. Would the codes be the same as the SVX?
Old 11-07-2005, 05:38 PM
Earthworm's Avatar
Meow!
Aside from the 2 extra misfire codes I believe they are the same. I've seen Subaru codes here and there and they often list the codes for all Subarus in one list with the slight differences noted.
Old 11-08-2005, 05:58 PM
elninoalex's Avatar
Registered Abuser
I appreciate the help, but neither of the two explanations seem to apply to my car as I don't seem to have anything similar to what you two are describing. Wierd. Chiltons manual(c'mon, it was free) is a joke as usual.
Old 11-09-2005, 11:23 AM
Earthworm's Avatar
Meow!
How about ?
http://www.ultimatesubaru.net/80s/specs/ecucodes.html
Old 11-24-2005, 04:17 PM
elninoalex's Avatar
Registered Abuser
I finally found those stinking wires. Apparently, they can be pretty much anywhere under there. They weren't even in the same place on both my 90 Legacys. Anyway, it's throwing about 10 codes. I used the clear function and it is still throwing them. I guess it's probably just a bad ECU.
Old 11-25-2005, 10:38 AM
Earthworm's Avatar
Meow!
I had a similar situation on my Justy - turned out to be just a bad battery. It's highly unlikely 10 sensors failed at the same time.
Old 11-25-2005, 01:40 PM
elninoalex's Avatar
Registered Abuser
I just remembered something, this engine was tripping the CEL in the other car as well, so it can't be the ECU. Maybe it is the battery. I did swap it over as well. Oh well, the car is running beautifully.
Old 11-25-2005, 03:54 PM
Manarius's Avatar
Manarius Manarius is offline
Read:
http://www.surrealmirage.com/subaru/engine.html
-Jason
-Obi Wan Kenobi
