New guy needs advise for a 4.44:1 VTD build
Hello all..
I recently, about a month ago, bought my first SVX. It is a 94 LSi, emerald green, with just over 84k miles on it, and in pretty good shape, so far, for the price I paid for it, in my opinion. Prior to this, I had not even known that the SVX existed. I have been a fan of Subarus in general for a few (several) years now, yet I have never owned one, personally. I was actually looking for a Baja turbo, but, this was a case of accidentally tripping over one and saying.."OMFG, WTF is that?".."Its basically an STI limited, 2 door, with a 6cyl. EJ3.3 that has the good crank bearing journals vs an EZ engine, and a 4eat, and its AWD? with cool windows and a Delorian body with paint"..."I need one!"...lol...it just so happened that I had the funding and the price was right and so, I now feel like Im 30 years younger, when I bought a '74 AMX 401 Javelin under similar circumstances...lol... I am continuously doing research on the SVX through these forums mainly (this one more than the other, but I do try to include all available, relevant resources and cross check info ), since the day I bought it, as I did due diligence in researching this car before I pulled the trigger on the sale. No need to spell out what Ive found online, here, where you know better than I. I am a mechanic by trade. I have been, for the past 34 years. BUT, I have been an aviation mechanic, specifically, since 1990. This is relevant because, as I might understand the theory behind an application, I dont have the hands on experience and access to specific tools and resources that an auto mechanic might be expected to have. for example, we dont use floor jacks on airplanes, much less impact drivers or car lifts, so, please bear with me. Any work that i choose to do myself would necessarily be done in an aircraft hanger, and some jobs I would simply prefer to "farm out" rather than tie up that hanger. Its a matter of logistics rather than competence...lol..point being, I can do a "power mod" in about 5 min.s, but changing a 250 pound transmision, solo, might go beyond my "will vs pocketbook", equation. Im not lazy, just "end result" oriented. I am a piston engine overhaul specialist, and I truly appreciate the value of experience over first time "follow the manual" jobs. OK, being that this is my first subjective post on this forum, and having gotten that primary introductory background info out of the way, we get to the meat and potatoes. My ultimate goal is to install a 4.44:1 trans. and diff., with a VTD center. I understand that this is potentially somewhat of a project on a USDM SVX. My strategy is, at this point, to do the 4.44:1 swap from a USDM '96-'98 legacy/outback to get the gearing in place first, along with a QC module and power mod.,. using the existing USDM SVX TCU and SVX torque converter. From here on, comes the questions. Can the JDM/Aussie VTD rear housing be transferred to a USDM trans. if the TCU is changed out/or not? or, would I need to swap the entire trans. and swap in the ring and pinion gears to the JDM/Aussie trans/TCU combo? I am aware of the trans. mount issue with the VTD tail section, and have the part numbers for those already. Are there issues with that gearing vs. the TCU's that need to be addressed? I have noticed that there is an existing 4.44:1 VTD trans setup out there...and I believe it has a QC mod too....lol... . |
Re: New guy needs advise for a 4.44:1 VTD build
ok..let me be a little more specific about my concerns..
I understand that a Phase 1, USDM 4EAT 4.44:1 trans from a 96-98 outback, not only has the different ring and pinion gear ratios, but also has different 1st and 2nd gear ratio's internally, than the stock SVX 4EAT. but if Im not mistaken, there are no problems with using the stock USDM SVX TCU with that trans., as far as shift maps, sensors etc., all the wiring is plug-n-play. I also understand that it is best to retain the use of the SVX torque converter if possible...And of course the rear differential gearing swap, but that is pretty straightforward and not where my questions lie......correct me if Im wrong at any point, please. OK, now...once that assembly is ( in theory) installed. From what I understand, the VTD tail section from a JDM or Aussie, Phase 1, 4EAT, can be swapped in to replace the original center diff., BUT, because of the difference in how the c-solenoid is utilized, and the difference in the speed sensor in the tail section, the TCU from a JDM/Aussie 4EAT, along with the rear trans/cross-member mounts, must be used. And the wiring for the speed sensor may need to be modified. I am making a leap of faith, that the TCU from a JDM/Aussie 4EAT will "play nice" with the different 1st and 2nd internal gearing of the USDM 4EAT from an outback., as far as shift maps, etc. are concerned. If not, then, the other option would be to remove the ring and pinion gears from the front diff. of the outback trans., and install them in the JDM trans., and use that entire assembly. (trans. and TCU) potentially still requiring a modification of the speed sensor wires. I would, of course, prefer to simply switch the tail sections and TCU, if its possible, for the sake of simplicity and cost. If there are any flaws in this plan, or details I am missing, any advise would be greatly appreciated. Thanks for reading through all my gibberish...lol...and thanks in advance for any insight you can provide. |
I bought a 1996 JDM tranny (3.70), sourced a 3.70 rear diff, already had a modified TCU with a removable ROM for the firmware. Then sourced a ROM with the correct JDM firmware.
While at it I installed a Quaife Torsen torque biasing diff at the rear and a Modena (similar operation principle) at the front. I like the set up very much. With a bit stiffer/lower springs, Koni dampers and a 19mm rear sway bar the handling is neutral. If you really want the lower gearing then you need get the maps modified. Starting with the JDM firmware may be the easiest way forward. You may also find a low mileage JDM tranny in good working order - I did. Claimed 55.000 kms..... so far so good - two years with a turbo charged engine including occational track days - no problems. Kind regards from Finland, Tapani Last edited by Tapani; 04-23-2015 at 10:12 AM. |
quite simply put, for a VTD swap, you not only need the VTD parts, but the c solenoid type must match the VTD TCU as Subaru changed C solenoid operation for VTD transmissions sometime in 95.
Along with that, you need VTD rubber transmission mounts, they are very different. |
Thanks for the responses, guys.
Tapani. I like the idea of going with TBDs too. I have heard that they can be problematic in snow and ice though. some people say that in very slippery conditions, they can act like an open diff. . You are probably the best guy to ask about this, being from Finland. Do they work well in the slippery stuff, or would a VLSD be a better choice for snow and ice? Also, what did you use to cut the axle shaft from the right rear? ( I saw your posts on that subject) I have access to a horizontal band-saw, a lathe or a cutoff saw, but im concerned about causing too much heat in the axle if I use the cutoff saw. are they soft enough for a band-saw to cut? Nate, I am aware of the different crossmember mounts and luckily have found the part numbers for the 3 separate pieces, in one of the other threads on the VTD subject. It looks like I can get away with swapping the tail section to the outback trans.'s main body as long as I can get a matching JDM TCU, and have some magic done to its firmware...lol.. Are there also differences in the c-solenoid based on production year too? and, is that c-solenoid typically included in the trans. tail section? or is that mounted in the main trans. body? Im going to have to be sure I get the trans and TCU from the same vehicle if possible, I see. I was hoping to be able to just get the tail section and TCU, but that might prove to be a challenge. wont know for sure until I find a source though.. Thanks again for the responses, guys. It looks like this is going to be a step by step, long term project, considering the costs involved and difficulty in locating and shipping of the parts. If you guys, or anyone else has any further thoughts or advise, Im all ears.....It looks like Im going to start out with a simple 4.44;1 trans swap, for starters, then start collecting the other pieces when I can find and afford them. Im sure more questions and concerns will arise, as they always do..... Best wishes, from the U.S.'s land of cheese, beer, and bratwurst... |
OH!...I almost forgot...
Does anybody know if the QC module and/or the "power mod", would be sufficient, to modify the shifting issues with a JDM trans/TCU 4.44:1 gearing? does the weak engagement of our slippery stock shifts and fuel cutout cause the issue with the 4.44 gearing, or is it more involved than that? keeping in mind that Im going to use the stock SVX torque converter too.. And, If it IS more complex than that relatively simple fix. does anyone know who I would have to contact to get those kind of mods done to a TCU? |
