Electrical GURU's....
What would cause my (Dash Lights) Battery, Oil, ABS, ect lights to come on and STAY on while driving down the road??? This kinda worries me... I had that electrical short a while ago and that fried the alternator.... So I replaced the alternator, but those lights came on today and they won't go off... They do, however, go off when I take my key out of the ignition... Any suggestions on what it could be???
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
Chris,
check back where the fire was...I'm guessing you've got a wire(s) shorting -Bill
Hi Chris.
Check the ground at the rear of the engine, that runs to the firewall under the ignitor block. It is the ground to frame for the engine. Might have been a bit burnt up too.
Also make sure the alternator is securely plugged in.
Get a volt meter to plug into the lighter (that actually shows volts). This will tell you what the alternator is doing.
Had you're alternator not been charging enough you wouldn't have made it home. Now, it could be overcharging which means DO NOT DRIVE IT YOU'LL FRY SOMETHING 13.2 volts at about 2k is what you're looking for out of her any more is worse than under 12. I'd go along with the wire as Bill said since you did jiggle it around a bit but if you bought a reman alt or if the rebuilder had over 50% of his teeth I wouldn't be suprised if that was the culprit.
