Water, water everywhere!!!
I know this has come up before, but I can't find the appropriate solution. My carpet on the right (passenger) rear side is soaked. Therefore, my windows all steam up overnight with condensation. I know there are drains everywhere and perhaps one or more are clogged. Where do you suggest I look for the drains and how do you clean them? Thanks.
Michael 1994 Barcelona Red SVX-LSI Two-owner:169K 1995 Emerald Green SVX L AWD #80 - Custom intake w/cone filter 99K with killer stereo system 2002 Acura MDX-Touring Edition w/navigation 2008 Toyota Prius 1987 Mercedes Benz 560SL |
Is it actually water? It may be engine coolant. A failing heater core will dump coolant in that spot.
Fluid
Antifreeze smells a bit like that when the mix comes out of a Heater Core, and through carpet. Slippery fluid?
The Worm _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
I doubt if is a heater core leak if it is on the rear area of the passenger side. Put some paper towels down on the carpet to absorb the moisture and see what color comes up. if its clear or slightly dirty, its probably just water; yellowish-green would be coolant
It could be the sunroof drain on that side. Check this thread: http://www.subaru-svx.net/forum/show...sunroof+drains You can also do a search for "wet carpet" or "sunroof drains" (without the quotes) .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-28-2006 at 07:30 PM. |
It is definitely water, not coolant.
oops
oops,, Reading to quick. Guess I picked the wrong week to stop ........
The Worm _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles Last edited by ShiuludeSVX; 11-28-2006 at 08:25 PM. |
There are also little drains in the trunk behind the rear wheels. These are in addition to the sunroof drains. They are hard plastic and will plug up over time.
You would have to take the trunk liner (and wheel liner) out to get access to them.
