Full throttle miss
Passing a truck way out toward Red Rock Canyon. I hit full throttle and it was like the fuel was cutting off and on. Very bad.... I had to let off cause it sounded like it was trying to yank the tranny out with a crowbar.
It's not throwing any codes, and idles and drives normally. It's just a full throttle thing. (Which is rare for my middle aged world anyway.) I tried it a few more times, and it's consistant... It doesn't like full throttle. Is my MAF about to give out? Is it that I don't drive it hard enough? In other words, is there truth to that "gotta blow da gunk out of it".?
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) |
When was the last time you replaced your fuel filter? That might be it as well.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
I can't speak for a gas engine but for my diesel semi, when the fuel filter clogs up from cold weather or leaning the semi and sucking up the junk on the bottom of the tank the engine will just sputter at higher RPM's and give no power. The more it clogs the lower the RPM drops. I don't know if that's the problem but that's what I was thinking before I read the other reply's. Good Luck and keep us posted.
pssssst..... all vehicles always suck from the bottom of the tank - always.
when's the last time you changed the spark plugs? WOT means max load on the plugs which can induce a high rpm miss...
-Bill
