here we go again with a stuck driver's side window
Hello All, Was a nice morn so decided to see if I could fix my Dr side window. It was only able to go two inches down and the same two back up to close. At each end point (up/down) it would buzz and stop. That is, if I was opening it, it would go down 2 inches, stop and buzz. Let off the button buzzing stops. to close, lift up on switch, windows goes up and closed then buzzed. Am guessing cable is hosed again. Managed to get it all the way down and of course it won't go back up now. Now I have no buzzing, no movement, no nothing when I pull up on the switch to close the window. Can't see if the cable is wrapped etc. Here we go again. Tried to pull up on window manually and while pressing button. Dead. Like I said..."was" a nice morn. Guess I'll look further...looks like I have caqble tension on both sides of that plastic clip...so I guess it's kinked/tangled...suppose I'll take out the regulator since I can't see S yet.
1994 SVX L FWD "The Blue Bullet" Last edited by powerdog; 09-19-2009 at 10:03 AM. |
Re: here we go again with a stuck driver's side window
If the motor stops after few inches and there is a buzzing noise from the swith, then maybe the express down feature is failing?.
95´ Subaru SVX EURO 85' Mercedes 190 2.3-16 86' Mercedes 190E 70' Olds Toronado 98' Renault Chamade 82' Honda Prelude 79' Honda Accord awaiting restomod. 69' Mustang Hardtop 67' Jeep Ford Willys awaiting restoration. 67' IKA Torino Coupe 74' Renault Torino Coupe |
well I've got no sound at all now. Window is almost all the way down. Cable appears ok. If I pull/push up on the window, I get tension on the bottom part of cable. Of course if I try to push down, I get cable tension on top of cable. Pulleys appear fine. Acting as though I've run out of cable so...what is preventing me from raising/lowering the window manually or in combination with the switch? (even though I can't tell if the switch is doing anything) because no evidence of power (noise). Only thing I am sure of is that the cable is somehow stuck (I guess). Question is how do I free it? Hrmph.
1994 SVX L FWD "The Blue Bullet" |
This is one where you just have to get in there and see. The operation of the window may have stopped completely now because of a blown fuse, an overloaded window motor can do that. A mechanics mirror is indespensible in cases like these so you can see the entire motor and regulator assy and find where it may be jamming.
If you have the correct tools, maybe you can check the motor terminals for voltage, when activating the switch, then you will see where the problem is located.
I know I have a multimeter around here somewhere. I don't think the motor is burned out...it was working until I pushed the window down...so I leaned toward a fuse but I do not find a fuse for the power windows...but then again, I can't see why the motor or fuse would be the problem. Seems mechanical/cable/regulator assembly related. MadMaxSvx, I assume I'd touch the meter leads to the terminals, activate the switch and check the reading. Questions: Is that correct and what kind of reading would I be looking for?
1994 SVX L FWD "The Blue Bullet" Last edited by powerdog; 09-19-2009 at 11:36 AM. |
I was looking up the troubleshooting on this the other day. Not for SVX specific but it was within the same years as our SVX and basic troubleshooting had you apply 12 volts to the window motor the window should move up if you reverse the polarity it should go down. If you do this and the window functions properly then atleast you know your problem is elsewhere. The driver's window is a bit harder to figure out though since the other windows have individual switches to help isolate where the problem could be. You make sure you have 12 volts going to your driver's window switch. If you have 12vdc supplied and you also can manually make the motor function it would be your switch assembly that is failing.
FYI -For other windows you verify you have 12vdc going to the drivers switch assembly if you have it going there then you verify you have 12vdc going to the passenger or rear windows switches. If you don't have it going to them then you driver's master switch is failed. If you do have it going to the other window switch positions and the window won't go up or down there then you have to also verify the motor same way as drivers before replacing the switch assembly. This is just from memory so I may have missed a step but it should be pretty close. |
Is it just the driver's window, or all the windows? (plus maby sunroof?)
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
If I connect the door panel (switch) the other windows work Right now with the panel off, none work. I assume that's normal. No sunroof.
1994 SVX L FWD "The Blue Bullet" Last edited by powerdog; 09-19-2009 at 11:56 AM. |
The other windows wont work with main swith disconnected.
1-If the other windows can be controlled from the main swith, then the fuse/wiring is good. 2-Plug the meter terminals to the wires going to the motor,when you push the switch, you will see a reading of (12v) or (-12v) depending if you press the switch up or down. If you have this reading (12v) or (-12v), then the motor is dead. If you have 0 voltage, then the switch is bad.
All windows work from main switch except driver. Can I test from the two blue plastic connectors in the attached photo? I have a blue and a blue/red wire(s). To what can I touch the tester?
To feed the motor with energy to make it roll up or down: A negative (-) wire from battery to the light blue wire and a positive (+) in the light blue/red stripe wire,will make the window roll UP,switch the wires to make it roll DOWN. I just tested it in my car.(I used the tester leads and a battery from another car to perform the test)
When the motor gets hot from being overloaded (jammed by something) they will usually stop working for a time. You can always jump 12V directly to the motor to test it, reversing the polarity reverses the motor rotation. With it out you can manually slide the window up and down to see if and where it jams.
Edit: Yes, if thats the connector to the motor, hook the main switch back up and test for voltage (as MadMax said) from the switch to those 2 terminals in the connector when switch is pressed in either direction.
Chris "A person convinced against their will, is of the same opinion still" New?? Find the downloadable SVX Online Service Manual Here RECOMMENDED READING for newer SVX owners Here some cool info if not fully accurate. Last edited by SoCal LS-L; 09-19-2009 at 12:43 PM. |
You mean if I take out the motor all the way I should be able to move the window?
If I jump from the battery, any ole wiring will do? Thanks
