Re: wats the best tranny for the 5 spd swap??
well i dont plan on racing but i do want it to have the ability to hold its own if i decide to place a lead foot on the gas pedal ok if theres no difference then which is the cheapest and will it have a matching diff?
p.s. whell mike wat hever dho yhou mhean? hi ahlways phut ahn H ihn the right plhace |
you can get a 5spd and just put a 3.9 in the tranny and u can use your stock diff.
personally from what i've heard from friends and known friends who broke wrx 5spds i'd only feel comfortable with a 6spd sti
no my diff is almost gone, if i turn at low speeds, its grinds LOUD. i was asking if i pull out a tranny from a subaru, will i be able to take its diff too and use that as a replacement? sorry but wat does 3.9 mean? and wat ratio is mine?
the stock gearing in an SVX is a 3.90 ratio some people who end up using the legacy tranny's change it to a 4.44.
you can take the diff too with the tranny but you might have to get a customized driveshaft cause the distance isnt the same and see if you can get a diff where you can stil use your stock axels
Stock final drive in an AWD SVX is 3.54 not 3.9.
The only 5 spd that will use the stock SVX rear diff is an WRX, their final drive is 3.9 but there is a 1.1:1 ratio on the rear transfer. Most Legacy/Imp 5 speeds are either 3.9 or 4.11, get the rear diff when you get the trans and follow SVXfiles write up to move your rear LSD into the new rear diff.
Stock gearing is 3.54
EDIT::Damn..... beat me to it
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
wait so if i do swap to a mt then id need to also get a longer driveshaft and a different axle for the new rear diff? sorry if im a bit confused, but say i grab the trans and diff from a junk legacy. i need to replace the axle to match up with the diff?
If you follow SVXfiles write up for the rear diff swap, you'll still have an LSD and use your stock rear axles.
You do need a longer driveshaft though. You can modify some 5 speed leg DS's or get your's stretched (see TomsSVX)
