#196
Re: SVX Engine cooling "Again & Again"
Great Job! Thank you for taking action and doing experiments for the group!
I think the next thing to do would be the following: Observe temperature of each bank at different rpm points: 3000, 3500, 4000, 4500, 5000, 5500, 6000, 6500, 7000, 7500. Record temperature, and difference in temperature between banks. Observe under which conditions that the present combination will overheat. (rpm, temperature, time) Last edited by FriendlyTurkey; 10-11-2009 at 08:15 PM. |
#197
I thought you had said the modified water manifold did not help?? Now it does?? What is going on here?
Tom |
#198
Tom the last time we tried the manifold was on the dune buggy (sand rail), that was what we were talking about. This is the first time we have tried it on a SVX car. You and I have a bit of a challange to get them to fit under the intake as the idle valve plug hits and the vacum chamber hits at the front. But other then that its all good and works well.
Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#199
Don't spend too much time off the throttle, you need to have a high pump speed and good heat input from the engine. Just like you are racing. Don't run off the road, don't hit a roo. Harvey.
#200
It was hot yesterday and the car cooling did some funny things, I have made some changes overnight and will see today. I will come back to you guys with an explanation tonight after we see how it performs today. In short the engine ran cooler yesterday but the radiator went to high, so I am checking things out.
Tony
#201
Nice progress Tony, please keep taking pictures of the progress you are making...
#202
I have been talking to PWR today about radiators and I am going to get them to build a radiator with some differences.
Top and bottom pipe to be larger as I think the current size is to small for the flow at 6,000 rpm (200lpm). On the bottom feed pipe to the pump it could cause the pump to cavate so to get round any possiability of this I will change the pipe on the pump as well. Harvey's diagram of putting the top pipe return in the centre is the way to go so while I am at it I will do that change and increase the pipe size. Next change is the number of fins per inch. Currently when you slow down the return tempreture of the coolent going into the pump shoots up. Also if I am traveling at 110kph and turn on the fans the return coolent temp drops which means the PWR air flow is poor. I read that a formula 1 car has 26fpi but if that was put in a normal car it would boil at normal travel speed on a average car. PWR told me they have 16fpi in the SVX ones they build and suggest that the OEM unit would have the same. My concern is that the PWR is twice as thick as the orignal but same fin number. The air can't flow through it properly this has the added effect of causing of the whole engine bay running hotter. I noticed that the SVX I have with the PWR boils the water out of the battery more often then the car with the standard. If you feel both bonnet under the same driving condiations you will find the PWR engine bay hotter. Guys with the sand rails tell me they are going away from PWR as they don't cool the engine as well as other brands. If I get stuck behind a truck on a hot day the return coolent temp goes up to a dangerous level as well. so what would happen on a race track. Sorry to have such a long post but needed to share my thinking. I am going with 12fpi reason 2 surfaces twice as think as the OEM means 48 equlivant to the existing 32 surfaces but maintaining airflow(got the quick crazy logic). Have a great day team will keep you posted (Are you still out there Trevor). Tony
#203
Sounds good to me mate.
Your car is a bit different to the normal SVX, in being raised on the suspension. This reduces the negative pressure that is generated under the car by the venturi effect of the airfoil shape of the under body. This creates a negative pressure in the engine compartment to enhance the airflow through the heat exchangers. So it may well be different to the std one. Harvey.
#204
DO you happen to know how many FPI on the standard radiator?
#205
I wish you well, Trevor.
#206
Hi Trevor good to see you are alive.
Not spending that much, my current PWR radiator is reaching the end of its life so it time to get a new one. Last one only lasted for 250,000k. My wife says I don't explain myself well, I am doing one step at a time, we have fixed the flow to the heads but now shifted the problem to the radiator. Coolent is coming back to high in temp so instead of buying the same radiator again I am looking at something different. Need to ignore the work on the buggy as I have no control over it and there are to many different factors to compare it to here. I figured out a way to test air flow in different radiators so I want to give it a go. Will keep you posted. Tony
#207
If your radiator is faulty, thats one thing. I still feel we are barking up the wrong tree with it as a solution though
Tom |
#208
Tom,
I think we need to have an open mind and try different things. If the pump flow is low we don't have much room to move in the radiator department. May be I have confused the issue the big change has to be the pipes to try to get more flow through the system at high revs. Ignore the rest. Tony
#209
Thanks for the run down on the radiator. This makes good sense. Also good that you are making any changes separately. What factual evidence do you consider indicates that, "more flow through the system at high revs." is required? You will get there, Trevor.
#210
Couple reasons I thinkwe should steer away from the radiator being the issue...
Jack is running a different rad in the EG33 RS Almost every dune buggy is not running our radiator either. While there may be inherent flaws in the radiator you are using, this may also be tainting the test procedures... In the engine you are using, have the head gaskets ever been changed?? At this age, every EG33 w/ original gaskets is suspect to needing a refresh. I think a proper test bed will need to have them done before we can take anything as an absolute Tom |
