Coolant leaking from front and back of oil pan
Guys, I've only had my SVX since November last year, I really love it, and it sucks that I found coolant dribbling fron under the engine today. Upon closer inspection I've noticed that it was leaking from the left and right (front ) and rear of the oil pan. It leaks when the engine is on. No overheating issues (yet), No green stuff in the oil, and vice versa in the reservoir. Could this be a head gasket failure? How much $$$(approx) am I going to fork over for this one? Thanks for any info.
92 LS liquid silver ---> pics here:http://s36.photobucket.com/albums/e8...VX%20LS%20AWD/ |
Re: Coolant leaking from front and back of oil pan
No green in the oil is good.
Put some dye in the coolant and go from there. Should help you spot it. Then do an oil change and check it. Also you can pull your exhaust off near the manifold, if its a bad head gasket then odds are you'll have the oil/coolant mixture in the exhaust. Make sure it's not dripping out of a normal hose/the coolant resivoir, and just running down and LOOKS like it coming from the oil pan.
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
If it's dribbling out and the car is running fine then I would very much doubt it will be a head gasket that is leaking the water. Not to say that loosing water couldn't cause the gaskets to go... if you are not careful.
Since it's a good sized leak it should be fairly easy to locate using a mechanics favourite tool... eyes. Might need a mirror and torch to make the looking a little easier. |
When the waterpump gasket leaks it likes to run down behind the timing belt covers and run around the lip of the oil pan. I've seen that happen on two of mine...
As always, diffacult to diagnose over the net. But water pump is my vote as well, especially if it's mainly on the drivers side front. That's how I got my SVX, my buddy had it parked for like a year or more because he thought it was the head gasket leaking externally. After filling it up with coolant (should have used water to diagnose), seeing the general area it was coming from, then looking at the subaru epc pictures of the cooling system, I negotiated the purchase. Replaced W/P and T-belt/pulleys, and life is good (at least with that issue). Hopefully this is all that is wrong with yours, as well.
Thanks for the info. I went underneath it again and I suspect the water pump as well. All the hoses are fine.
Thanks for all the info. The car runs/ drives ok. But I'm definitely dropping it off this weekend or monday to be repaired. Hopefully it's something minor.
