Noise from exhaust in park
When my car is in park and I rev the engine and then let off the gas I get a kind of pop noise. Is this a bad thing? I have a stebro exhaust and an air intake.
Re: Noise from exhaust in park
In case you never got an answer...it's fine. Mine does the same thing with the Stebro.
thats what I thought
my 180k system "hiccups" when deccellerating..i wonder if a bad gasket is causing this? who knows
phil
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
Phil,
You are exactly right, it is a very good idea to check for an air leak close to the manifold.
I also "mostly" fixed an exhaust leak immediately in front of the center cat. It will be completely fixed sometime this winter when the 5spd goes in.
