oil pump gasket replacement cost
Hi,
just wanted to know how long it should take to replace the oil pump gasket - mine is leaking. Also what is the approx. cost for the actual gasket?. thanks
Re: oil pump gasket replacement cost
the oil pump has a o ring and uses RTV sealer ,if you can do T belt you should be able to fix it replacing the front seal should be done to along with sealing the rist pin access plugs
most dealers i have worked for charge around 3 hours for a belt and another hour to reseal the pump ,one other note be sure to check the screws on the back of the pump to make sure there tight,the crank seal is under 10 and the o ring is under 5 dollars Last edited by trophy956; 06-18-2017 at 09:56 AM. |
