Old 08-02-2017, 08:39 PM
Dr. Spaceman Dr. Spaceman is offline
Waving yellow
Phantom oil leak
Solved!!!!
Old 08-04-2017, 05:04 AM
Re: Phantom oil leak
The oil on top of the engine is probably a clogged PCV valve, but that should not have anything to do with the drips on the driveway.
Old 08-16-2017, 10:10 AM
Waving yellow
Solved!!!!
Old 08-17-2017, 07:14 AM
Are you on Facebook? The SVXNation group is a lot more active than this forum, think they could probably make some helpful suggestions.
Old 11-13-2017, 10:07 AM
SoCoNoHa's Avatar
SoCoNoHa SoCoNoHa is offline
H6 Fanatic
Any headway on this? I hope to reseal my EG this winter, and would appreciate any insight into potential problem areas. My SVX tends to mysteriously leak oil as well. I've replaced the PCV and added a catch can, so that should be fine. Hopefully it's just the cam seals?
1992 SVX LS-L : King of the Stable
LGT 5MT, ABS Delete, Short Ram Intake, Custom Exhaust, Drilled/Slotted Rotors
1993 Legacy sedan : winter beater, supposedly.
1994 Legacy wagon : future drift car?
1995 Impreza coupe : EZ30++, daily racecar.
1997 Legacy GT : date night rocket?
2003 WRX : future winter beater
Old 11-14-2017, 05:39 AM
simboglide's Avatar
simboglide simboglide is offline
My experience with a front engine leak was the oil pump seal, also, 2 of the screws for the O/P cover had worked loose. New seal and some blue thread lock fixed that leak. As for the top of the engine, my guess would be the power valve, mounted with an oring, to the bottom side of the intake.
Old 11-14-2017, 05:31 PM
Waving yellow
Solved!!!!
