SVXBot
Go Back   The Subaru SVX World Network > SVX Main Forums > Technical Q & A > Chris's SVX Shop
Old 04-19-2007, 09:57 PM
Dominus's Avatar
Dominus Dominus is offline
Homo Sapien Superior
Easy way to clean IACV
I read somewhere there was a tube you could spray cleaner in to ungunk the IACV. Is this true and if so which tube is it?
“Veni, Vidi, Vici.”
Old 04-20-2007, 06:15 AM
joburnet joburnet is offline
There's a writeup of how to clean the throttle body and this is part of it, if you do a search you should be able to find it. From my memory it's the hose on the drivers side that connects to the air intake where it connects to the throttle body. There are two hoses there, if you can find the writeup then it has pictures.
Old 04-20-2007, 08:30 AM
JaySVX's Avatar
JaySVX JaySVX is offline
If i am guessing correctly, your thinking of seafoam:
http://www.seafoamsales.com/images/Deep-Creep-small.jpg
You can get more info here:
http://www.seafoamsales.com/products.htm
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 04-20-2007, 11:41 AM
Dominus's Avatar
You don't have to use seafoam do you?
“Veni, Vidi, Vici.”
Display Modes Rate This Thread
Rate This Thread:
[IMG] code is Off
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
