Wiring for manual gearbox on Oz, JDM & European Cars.
Okay a couple of guys have contacted me to help sort out the wiring on there cars. Most of the cars outside of the USA are wired different so they need to be sort out differently. As I see it these things need to be worked out if I have forgotten please speak up.
- Starter. - Speedo. - Cruise Control. - Reverse light. Is that what everyone needs. Tony
Re: Wiring for manual gearbox on Oz, JDM & European Cars.
all good to know, i am in need of the last 3 points, also thanks agin for doing this!
1992 Pearl / Black SVX removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads |
i will be interested one day soon
Hi guys,
Im also searching for the wiring. all i have is : speed sensor wires, but dunno which wire is what : http://img17.imageshack.us/img17/6499/svxconnectorc.jpg reverse light wire: http://img7.imageshack.us/img7/7795/rckfahr.jpg greetings |
Its me again!
here is the wiring of the european svx! there you can see, which wires the speedo has on the tcu. http://muellertimo.privat.t-online.d...X-ATF-Docs.pdf so white goes to tcu. black and yellow to an extra connector B69 greetings Last edited by fluo; 05-09-2009 at 07:29 AM. |
JJ I hope you didn't wire the starter through the gear box netrual switch. The reason is that the gearbox switch can not take the direct current for the stater and will bur out.
Tony
Thank you for the German diagram scan. That is very interesting to see. From our research it would appear the German market SVXes were equipped with the ACT-4 gearbox. See thread here: http://www.subaru-svx.net/forum/show...any#post485067 UK, Australia/NZ and Japanese SVXes were supplied with the VTD gearbox. These markets were all RHD. In this VTD type gearbox the speed sensor signals both come from inside the gearbox, but with the ACT-4 type one of the sensors [SS2 I think] is fed from the differential housing and is the Hall Effect type. The reason I mention this is because I would expect your speed signal to the speedometer to be coming from the additional wire beside the dip stick for the differential of your auto, rather than in the wiring loom [cord] running up the left side of the gearbox, as it would for the VTD type. I hope I am making this clear enough. Assuming I am correct about your gearbox type this may imply but not guarantee that whatever speed signal re-wiring the US owners have done for manual gearboxes will also work for your German gearbox. By implication what the Australian guys have to do to keep their speedos working may be a little bit different, becuse I don't believe their speedo gets the Hall Effect signal. Joe
