vibration in rear of car
I was wondering if anybody had an idea about what the problem with my car is? I have a 92 Svx and the rear of the car is vibrating pretty bad. It happens when accelerating and decelerating. It happens from 0 to 10 miles per hour both ways. any help would be awesome. Thanks
Tires?
If nothing else appears wrong, I would check out the tires first. My truck was making an odd noise and a vibration was present as well, it ended up being a defective tire. If not, it could possibly be rear diff problems. Steve
It's not a car..it's a boat!! |
I doubt it's tires unless it happens at higher speeds. Any other info you can provide for us?
Rotate your tires to see if the vibration moves location.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 12-05-2006 at 01:40 PM. |
I have the same issue in my '92 as well. Symptons are identical.
My guess would be bad joint on the driveshaft, I had that on my car. Is it coming from around the center console?
Mine is definitely coming from the back of the car. I am 100% positive
rear differential
My car has that and I had the car looked at and the mechanic said it's the rear differential.
Check me out and tell me what you think. And vote on my poll. http://www.cardomain.com/ride/2148680 This is the day I got my svx, and took it for a test drive, while helicopters watched. http://videos.streetfire.net/search/...6373e299d2.htm |
Try inserting the FWD fuse and driving it a bit. If the problem goes away you have an issue to the rear, if the vibration remains look forward. Inner cv joints can cause vibration under accel/decel conditions without noticable hi-speed vibration. Driveshaft u-joints can also create this type of vibration under load, rarely during decel and are almost always accompanied by squeaky noise during accel. Or at least a good 'whang' when placed in gear from park/neutral or a change of direction.
Differentials rarely cause vibration at low speed, unless they have been making hi-speed vibrations/noise for a long time. Typically, differential noises come from worn/damaged bearings. Mesh noises occur either a) immediately following a rebuild or b) after bearing damage has occured and allowed the mesh to change.
A bad tire (slipped belt) will often show itself as almost a boat-likes swaying of the car at low speed.
-Bill
