svx good in snow?
Well we had a couple inches of snow/sleet here in northeastern pa. I was driving my svx and i was all over the place. I drive fairly conservatively especially in bad weather and was shockingly surprised at the instability of the svx in the snow. The only thing i could think of blaming the lack of control was on the tires. I am running p225 50 toyo proxes. Do people with this same width/height tire have similar problems in the snow. I mean i am not floundering all over, but i did happen to fishtail on one turn, and slid at numerous stops. comments welcome, thanks Chris
Mine handles extremely well in the snow. However, it has bridgestone Blizzaks (snow tires). Tires make a HUGE difference in the snow.
yeah my tires are dry and wet classified. The car handles exceptionally well in dry weather, just didn't expect it to be this bad in the snow. I just have to drive a little more careful. This is the only winter my svx will be driven so i'll just nurse it the rest of the season.
my svx is a tank in the snow with my Dunlop Mud+Snow rated tires.
It must be your tires, chris. Mike |
My Dunlops SP5000's are mediocre in snow, but the fact that the whole car does extremely predictable 4 wheel slides is what makes the SVX very well balanced, if you have a full tank of gas, the rear end will not slide as easily.
Its all that power, and weight that makes the car slide. And of course braking can be a chalenge at times without great snow tires. I would suggest lowering your tire preasure to 25lbs for good snow traction, assuming you have lots of tread. My advice is only for the heavy snow, low tire pressure will cause uneven tire wear on pavement.
Chris G 92 Pearlie, sold @ ~209k miles. Now owned by Tim. Current Ride, 1985 Honda Aero 80, stock 3024 klms |
i'd go with the tires also, i have mud and snow rated b/f goodrich tires, and its pretty amazing in the snow, although i have noticed in some cases that pulling the ebrake will actually stop the car faster than the ABS... not all the time, but if the conditions are just right... AWD helps you go... doesn't doo much to help you stop
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker |
I find my car does very well in the snow as long as its less than 6 inches deep. M+S tires with about 1/2 tread left.
We got robbed last nite we were supposed to get like another 5 inches . I don't see it
Whereabouts in NEPA Svxman?
My SVX has been better....
It used to do real well in the snow but last night I had all sorts of problems. I'm assuming its my tires. It doesn't help that i have yokohama Dcbl's with only 2/32 tread left. Oh well, i'll try and make a point to get new ones soon.
~Ray
'93 LS-L named "Samantha Victoria Xavier"...Sam for short. All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter. |
My Tires (Yokohama Avid V4s) seemed to do really well in the snow last year when they were new, this year not as well.
P.S. Ray the quote is "I may not agree with what you have to say, but I will defend to the death your right to say it." I believe it was Thomas Jefferson.
-Steve Member #895(the member formerly known as BurgundyBeast) 01' MSM Lexus IS300 |
I have 18 inchers with 40 series high performance summer only tires, and when NY got 14" of snow in December, the car was great. Every car is pretty unstable in deep snow, but my SVX was more surefooted than many SUVs I was passing, and the 4 wheel drifts are awesome...fun, yet predictable.
Most cars will handle well in the snow with good snow-rated tires, but for the most part, the SVX sucks in the snow. End of story. Use the manual button while the gear selector is in 3 and this will help prevent spinouts from a standstill.
~Ray
