Old 05-19-2015, 06:44 AM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Re: Hub-centric rings on Enkei Shoguns and tire size
10mm difference in offset may make the the chance of an outside rub on the rears with a weight load a bit easier...my rubs, as rare as they are, would probably not occur if the rear strutrs were a bit newer. I bet you'll be alright but certainly 225/45-17 should be no problem. I have used these and 235/40-18's w/o a problem.
Old 05-19-2015, 07:35 AM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Thanks for the info. I'll give them a shot and see how they turn out and let you know
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 05-19-2015, 09:03 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
I have been running 235/45/R17 on 17x8 wheels with 48mm offset. Never a problem and the speedometer appears to be right on.
Gene and Ben
Old 01-25-2017, 08:22 AM
halistan's Avatar
Grand Poo-Bah
Just an update, finally got new tires installed on the Shoguns last night and found the correct hub-centric rings. For these wheels the center bore is 73mm and the SVX is 56.1mm. Got the rings on last night, and tonight i'll move everything out from around the SVX so i can get it out and put the new wheels on
Oh, i went with Michelin Pilot Sport AS/3+ tires. They seemed to have the right balance of everything i was looking for so hopefully they will work well. I'll post pics once i get them on.
