SVX Help, have 3 main issues
Hello ALL!
I am a new member and i've been reading many posts on how to fix my car. But there are some that i can't seem to find exact answer too. So maybe you guys wouldn't mind helping me out a bit. There are 3 main problems that i think many of you are familiar with but couldn't find the answer. So If you guys don't mind helping me out, that would be great. Here are the 3 problems, 1) Just recently I was having shifting problems in 4th gear. It would seem to go into 2nd or something with high revs. I adjested the TPS (to 0.5 V)wich seemed to have fixed that problem but made others. Now in 4th is seems to only slip into 3rd (not so high of revs) but i only notice it when i am using cruz control. 2) After adjusting the TPS i have been having idle issues. With a warm car it will idle at 1100ish and then tries to drop lower. But the car starts to die and then the revs go back up to 1100ish. And the cycle contines. Sometimes with a cold/warm car it will idle around 1700 and just stay there. But if i turn the car off and on again it will idle ok with the above issue. 3) This issue seems to be known but not solved. Its a starting issue. Sometimes it works fine, but mostly it just clicks about 7 or so times before that starter kicks in. I read similar issues but no solutions. I think its a reply somewhere but don't know where to start. Oh yeah, starter and solenoid were jsut replaced hoping it would fix the problem. Well those are my issues that i need help with. The first 2 are probably the same problem with the same solution but you guys seem to know this car inside out!! Thanks in advance. Oh yeah, one thing the SVX needs is a Lambo door kit. Would look sick with the Lambo doors. |
#3 is ussually the ignition switch. There is a plastic part on the back of it that wears out over time and the contact can't be made to trigger the starter. Try searching for it, you'll see some pictures.
-EDIT- This may help you. http://www.subaru-svx.net/forum/showthread.php?t=27339
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? Last edited by Speedklix; 04-28-2006 at 02:30 PM. |
Yeah thanks for that link, i started to search but couldn't find anything. Well I will have to look at. Thanks i will give it a shot
try disconnecting the negative terminal on the battery to reset the ECU. Leave the terminal disconnected for 30 minutes at least. This should allow for the TPS adjustment to take full effect and it should drop you idle. With any luck it will fix the shifting problem you speak of as well. It sounds all too much like the typical high clutch giving but it may not be.
Tom |
Thanks Tom for your input, i will give it a try.
Your starting problem could be the ignition switch, it could also be the inhibitor switch (nuetral saftey switch). Try switching to nuetral before you start the car. Also switch through the gears then back to park, then try starting it. If all fails, you can try the temp fix called 'starter relay bypass mode'. Good luck.
