how to recognize pin 4 in the TCU to install the power switch?
Can somebody help me with some images? my TCU have 3 connectors. check the attached picture
Re: how to recognize pin 4 in the TCU to install the power switch?
Everything you need to know is in this thread:
http://www.subaru-svx.net/forum/showthread.php?t=39133 If you want a proper pin to put in the connector you can steal one from the 20-pin manufacturing diagnostic connector in the footwell. That plug is never used once the car leaves the factory.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II Last edited by b3lha; 06-18-2011 at 02:39 PM. |
Thanks b3lha. very good info. Now I feel ready to do it.
If its not too much ask, can you please tell me how to recognize the 20 pin manufacturing diagnostic connector? may be a picture... IŽll document my installation and public it at the end. Thanks |
To remove a pin, unclip the flap on the back. Then sticking a needle in from the front and lift the plastic catch while pulling the wire from the back. Once it's out, snip the wire off an inch or two from the pin and join it to the wire from your power mode switch. The pin will click perfectly into the TCU plug, but be sure to put it the right way up.
This thing works great!
it is another car with this power on. new performance. thanks again! |
