Extra fog lights
I got some extra little fog lights that I mounted on to the front bummer but need some help with wiring I want them to be on the. Same switch as the fog lights by the head lights but don't know how to wire them up please help pictures would be great too thanks for reading
Re: Extra fog lights
What you're doing may not be legal onroad FYI. You are only legal to have 4 forward facing lights on at one time.
WOW Nate - that's is a bit rough, here in NZ there is no limit - I had 6 on my mini (2 + 4 spots).......
You could take a wire from the hi-beam side of headlights to a relay sense side, then hi-current from battery to relay & earth to the low side of relay - this setup will work with normal hi-beam stalk switch. If you want to also fit a manual (hidden switch) then fit it into the initial line that runs from Hi-beam to relay line. |
How would you wire the extra lights if I want to use the parking light switch on the lower dash next to the control for the mirror heater. Then they would be independent of stock fog lights.
We did not get the fog lights as an option here in NZ - there is a blanking metal plate inside the housing - thought about retro-fitting them into the original housing (even got lamps from USA model sent out here - maybe one day) - but prefer to keep my NZ housing as it has glass not plastic out front..
Oh how I'd love a set of glass housings. I do have a friend in Germany. |
