removing 5spd from donor car
anyone have any idea roughly how long it would take to remove the trans, rear diff, master cyl, slave cyl, shifter assembly, pedal assembly and flywheel from a donor car? that is, with all the tools. and if anyone knows off hand the specific tools and sizing you need for any of this, go ahead and post them! thanks a bunch! i want to be as prepared as possible for this!
depending on how mechanically experanced you are i would say between 2 and 8hrs.
it took me 2 hrs to get the pedal cluster and transmission out of the legacy i used as my donor car but the motor was already gone
1991 xt6 eg33? 1993 gc track car |
alright, thanks. so it will be a lengthy process. its ok, its for a good cause
Well assuming every bolt comes off, you're using air tools and it is on a lift maybe 3 hours. In a yard add 3 hours. If you run into any issues at all add 1-3 hours. Since you're asking I'm assuming it's your bleeding time add another 3 hours to do it right. If you haven't memorized what all needs to come off prior to doing it from a FSM add yet another 3 hours. Total 3-12 hours give or take.
Tools various extensions a 8. 10, 12, 14, 17 and 19mm ratchets and wrenches. Breaker bar for the rear diff, phillips head screw driver. Pry pars and a BFH should do it. |
long story short, my father who i talk to once a moth for maybe 5 min found out about my 5spd plans, and contacted a guy he knows who owns a salvage yard somewhere in IL, and said the guy owes him so many favors, hell make it so hell just let me tow the whole donor car home for a few days, take what i need and tow it back, with the parts i dont need. i hope that works out. free 5spd swap!!?? awesome!! well, minus what i need done by tom. still not bad. we shall see! wish me luck, ill know in 2 days if i have a donor car or not!
thats awesome! take your time dissambling it. I was going to just hook some chains up to my neighbors Forrester and pull it in my garage, returning it the next day with a nice 3.54 automatic in its place
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
