SVXBot
Old 11-08-2019, 05:41 PM
Pristine Green Polo Machine
Re: 1:18 SVX scale model in production
Another example. And the interior is accurate as well
1996 Polo Green LSi #216...137,900 miles...
JFICX8659TH100216JF1CX8659TH100216........Mfg. Date: 11/1995.........In-Service Date: January 2, 1997
HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, Raceconcepts dimpled/slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler.
R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a COW March 4, 2016
2014 Hyundai Elantra Limited ...109,000 miles. Actually quieter and smoother than the SVX
Old 11-08-2019, 08:03 PM
wdb wdb is offline
dances with roads
Hurrah for removing the wing! Not sure if I’d buy one but much more likely if it is sans wing.
2007 BMW 328i Cabriolet
2007 BMW Z4 M Coupe
2012 Tacoma 4wd v6 Access Cab
2011 Lexus GS350 AWD
2008 Honda Fit - hailed to death
Old 11-08-2019, 08:37 PM
Originally Posted by wdb View Post
Hurrah for removing the wing! Not sure if I’d buy one, but much more likely if it is sans wing.
Since I am fairly sure the body would be painted and buffed before the spoiler was attached, I wonder if you could request to leave it off on your order (unless there were mounting pins and holes already molded in to facilitate consistent alignment)
Old 11-09-2019, 04:34 PM
wdb wdb is offline
dances with roads
In that case put me on the "definitely maybe" list.
2007 BMW Z4 M Coupe
Old 11-10-2019, 03:10 PM
At 1:18 scale, the model measures a bit over 10” in overall length, 4” wide and about 3” in overall height.
Slightly smaller than a 8.5” x 11” piece of paper, folded lengthwise.
Old 11-12-2019, 08:02 AM
I'll take a blue one if it is a decent $$$
Old 11-12-2019, 08:43 AM
John
They are producing the 1991 SVX. After looking at the 5 colors offered in 1992, they originally considering doing them all in the Claret and Black paint scheme. But then changed their mind and are producing them all in the iconic white pearl and black, with dark gray interiors.
There probably will be a limited production run of 350, all pearlies, individually numbered chassis.
Preliminary estimate on price is between $175-200 USD each, plus shipping from Switzerland. There will also be clear acrylic display cases to order separately.
I will let everyone know when it is possible to pre-order. Paying ahead assures you will get one and a 10% discount.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
