Old 04-10-2007, 01:43 PM
svx0104 svx0104 is offline
1SICKSVX
Tri state sticker
any body else have this sticker on the back of there car ???????
Old 04-10-2007, 02:18 PM
Sticker?... What sticker?...
Old 04-10-2007, 02:54 PM
1SICKSVX
this one on the left it is under the clear coat
Old 04-10-2007, 03:54 PM
Dengue's Avatar
Dengue Dengue is offline
My kitten can woop your kitten
Send a message via AIM to Dengue Send a message via Yahoo to Dengue
EEEEEWWWW!!!!!! a dealer sticker... you should send them a bill for advertising. bastards.
'95 SVX L - Laguna blue 126,000+ miles
'89 XT - some sort of sun bleached blue
'00 Hyundai Sonata- charcoal gray (hers)
Old 04-10-2007, 04:01 PM
SVeXy96's Avatar
SVeXy96 SVeXy96 is offline
Sold my soul to Subaru
Yep...dumbazz stealershipdid it...they always have a way to mess something up!
Old 04-10-2007, 05:28 PM
1SICKSVX
and i do nor know how to get it off it is under the clear coat any suggestions???
Old 04-10-2007, 06:05 PM
It's Just Eric's Avatar
Missing in action
Your prettymuch screwed. Best bet is to wet sand that corner with 400 till you break through. Then try to peel that billboard off/out. Continute to wet sand the area with 400 until theres no edge in the clearcoat. Go over that with 600 wet, just to get the scratches out. Then go over it with say... 1200 wet. If you havent broken through the original factory clearcoat by now...you can simply buff the area out. If you've broken through to basecoat, youll have to have the area re-cleared. If such is the case, a few weeks after the clearcoat dries, wet sand the peel out with 1500 and buff it to make it match a bit better
R.I.P Cool Signature.
Old 04-10-2007, 07:24 PM
DanSVX94's Avatar
DanSVX94 DanSVX94 is offline
Ren-Ma Osu
just get a little sticker to put under the tri state sticker that says sucks sux then go to dealership and tell them to remove their ad or you'll leave your ad modifier
Used to have: 1994 Pearlie, 40,945 miles, PWR Radiator, Motorsports Aluminum Crank Pulley, Raceconcepts Stainless Brake Lines, Axxis Ceramic Brake Pads, ATE Super Blue Racing Brake Fluid, Dimpled/Slotted Rotors, BBS STi 17 Silver Wheels, Toyo Proxe4 225/45/17 tires, New Dekka Battery, Unauthordox Racing Oil Cap -- adds 3.14 hp, OEM Coin Holder FFTDS aka Force Field Theft Deterent System. Magnetic oil drain plug, Purolator larger oil filter. Now she's in good caring hands at Earls place.
Old 04-10-2007, 10:54 PM
That is the last thing I would want.
Old 04-10-2007, 11:15 PM
~*~JenSVX~*~'s Avatar
~*~JenSVX~*~ ~*~JenSVX~*~ is offline
J. Bond
Send a message via AIM to ~*~JenSVX~*~
If its the sticker type on a past svx I removed it similarly to debadgeing a car with a heat gun. Took a while but it was worth it.
J. Bond 7
1994 Laguna Blue
www.longislandsubaruclub.com
LISC member #50
Old 04-11-2007, 09:52 AM
1SICKSVX
so it is not likely it was shipped like that the dealer put it on and then recleard it
Old 04-11-2007, 10:48 AM
J. Bond
Yeah not likely the dealer would clearcoat their sticker on there...
J. Bond 7
1994 Laguna Blue
LISC member #50
Old 04-11-2007, 01:42 PM
1SICKSVX
who's is this
Old 04-11-2007, 06:45 PM
Missing in action
if it really is under the clear, could've been a bodshop using the rear quarter as a blend panel for a door repair. Stickers and such SHOULD be removed, but if, say, the customer wants that sticker there, like hell a bodyshop will try to mask that off only to have the clear lift at all the edges and the job to return under warrenty.
Like I said..if it IS under the clear, foow my previously posted instructions. If it is actually just stuck on there really good, try a heat gun. If that doesnt work, a rubber wheel will
Old 04-13-2007, 01:45 PM
1SICKSVX
thanks i will do my best to get it off and send them the bill damn dealerships trying to advertise for free and ruin my car
