Headlight Cleaning site down read only board (cant read)
the instruction site for hosting the write up on headlight cleaning is unavailable. Who copied all the steps. I just got the cleaner ad I need to know what sandpapers to buy.
Yepp I kicked the server 2 days ago and I have to fix it.
What sand papers? You'll need 400, 800, 1000, 1500, and maybe 2000 Wet sand then use the plastic cleaner
Lwin M. Maung (Member # 147) Current SVX: • NONE Previous SVXes: •1994 LE Barcelona Red 107k • 1992 LS-L Pearl White 143k • 1994 LSi Bordeaux Pearl 220k • 1992 LS-L Ebony Pearl 184k • 1992 LS-L Liquid Silver 145k • 1992 LS-L Liquid Silver 102k • 1992 LS-L Ebony Pearl 123k Other current cars:•2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
where do you get those sandpapers
awfully fine grit. Have you ever used novus plastic cleaning supplies? Do you have it in a word, pdf, or zip file maybe. Just fro oven temps and such. The wife and I are going to try to get paint off my vandalized ones and get em back to new. Any info is apreciated.
Anyone want to split sandpaper cost?
if anyone has found a good assortment pack of fine grit sandpaper at a good price let me know. Or maybe a few people can order a pack a peice and send em out snail mail? I dont want fifty sheets of 1000 grit
My local Ace Hardware sells it in single sheets (although not cheap that way), and one of each is more than enough for headlamps.
gotta find an ace
Aces seem to beclosing left and right. Ill try to find a different one close to my house. Thanks for the tip though.
You can replace some of those grits with elbow grease mabey just 800 and 1200 will be necessary. I usually finish with plastic polish, then wax. Somebody verify this, I believe you heat the oven to 400 then turn it off, put the lights in and wait 10 min till you take them out.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
Re: where do you get those sandpapers
Sandpaper:
400 600 1000 1500 2000 Alternate sanding direction. If you do 400 left to right, do 600 up and down, then 1000 left to right, etc. Compounds: Rubbing compound (Novus #3) Polishing compound (Novus #2) Plastic polish (Novus #1) I used Krylon Clear Coat in a spray can and it has held up for over a year and a half in Wisconsin winters and highway driving. Doug
Doug,
call me in the AM.
I'll call you around 10 Doug
Clear Coat?????? Yikes
Man I dont know about some clear coat on my headlights. Thats scary. Maye Ill just saran wrap them, hahaahh JK. Clear coat is strictly for finish or does it protect from fogging, cracks, or any of the above?
Re: Clear Coat?????? Yikes
Doug
