Old 10-16-2012, 06:16 PM
Rim that fit
Found this. Could be useful
http://www.autosportz.com/article_wh...m_fits_car.htm
Question : are all Subaru rims the same bolt pattern and center hole. 2003 Legacy rim fit an SVX ??.?.
And to compare tire size this works great
http://www.rimsntires.com/specs.jsp
Old 10-16-2012, 08:16 PM
Re: Rim that fit
No most Subarus are 5x100. It is only the SVX and the STI that are 5x114.3.
Old 10-16-2012, 08:21 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Re: Rim that fit
And Tribeca
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 10-16-2012, 09:15 PM
smc smc is offline
Re: Rim that fit
Technically, aren't SVX's 5x114.0 and STI's 5x114.3? I seem to recall reading that here at some point.
Old 10-16-2012, 10:06 PM
Re: Rim that fit
I think not. You may be confusing the bolt pattern with the offset; SVX being +55 offset and STI being +53 offset.
Old 10-17-2012, 08:26 AM
SVX_MY_BABY's Avatar
Re: Rim that fit
I wouldn't trust that site. I have an Audi A3 2008 which uses a 5 x 112 bolt pattern. The site shows it as 5 x 100.
Peter
Old 10-17-2012, 08:34 AM
Re: Rim that fit
No. They are 5 x 114.3 (or 4.50 in.) per page 4-2 of the service manual.
Is there such a thing as a 114.0 pattern?
Peter
Old 10-17-2012, 11:41 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: Rim that fit
A quick glance around the web suggests that Hyundai and BMW have been known to use 5x114.0 and Chrysler's used 5x115.0.
You'd think that automakers wouldn't mind a little bit of convention!
Old 10-18-2012, 06:30 PM
Re: Rim that fit
Will 38 to 45 work on the SVX
SVX says 42to50
Is it that tight of dim? 42 min. And 38 is to little. Will that mean it will stick out farther or rub the suspension ?
Old 10-18-2012, 06:48 PM
92 SVX 92 SVX is offline
Re: Rim that fit
GM uses 5x115 on several of there FWD cars, though 5x114.3 will fit as long as your rim is not bolt centric. and even then it generally works.
That would go for 5.x114 as well.
Old 10-18-2012, 11:37 PM
smc smc is offline
Re: Rim that fit
Good to know. I never bothered to check up on that, I just recall reading it at some point on an svx site and took it heart. My gods, everything you read online isnt always correct?!?
Old 10-19-2012, 03:16 AM
Re: Rim that fit
Soo is the 5 114 going to work with the 5 114.3 ?
35 offset With a narrow 205 60 16 tire will it work ?
