Making My Own Clear Headlights from Lexan
Since the smallcar clear headlight kit is so expnsive I've decided to attempt my own clear lenses. I bought a sheet of Lexan to try and use. I haven't finished the first "lense" yet, but it didn't take long to do what I did so far. I'm going to make them shaped as similar as I can so installing them will be very similar to smallcar's.
I'm using an existing headlight as the mold and just temporarily attaching the lexan to it so I can use it as a mold. First I cut a piece to the approximate size of the headlight face. I'm heating it up by holding the face of the headlight over top of my electric stove on HIGH. It was so hot that it started to melt my oven mitts This is where I screwed up. To keep the Lexan on I used double sided tape. Big mistake, I should've known it would melt once it got hot. I'm just gonna finish up this first test piece with the double sided tape, but I will have to find out something else to use next time. Anyway, the lexan molded pretty well to the top to bottom and left to right contour of the headlight. There's one spot though, where I held it too close to the burner and it started to bubble and warp. A mistake I know not to do next time, also not to rush. When I was doing the top lip, I just heated the whole length of the top side of the lexan. Once it was soft enough I just molded it to the shape of the top part of the headlight. Making sure I held it in place so it didn't spring back to its normal, flat shape. Here's 2 pics of what I have so far. If I finish these the way I like it, I may make a few extra sets to sell if anybody would be interested. I would sell them at a MUCH lower price than smallcar. Or if anybody would want them installed you can send me your headlights and I can make them and fit them at the same time. This would be another discussion for another time though. Just thought I would throw the idea out there. Please give me any feedback, positive and/or negative about this people!
bLAh
I would be interested in a set. If you can do this well and sell it for less than small car I think you be able to sell quite a few.
I'm not too sure on the price right now, but it will definately be less than half of what small car is.
I just got finished molding the bottom lip and one side lip. Now that I have a little more experience with timing how long to heat the lexan it's getting easier to mold it. I think I'm gonna make another "test" piece before I make my personal set, then I will start making sets to sell. Everything would be so much easier if I only had a heat gun. It would save me from sweating like a slave too
bLAh
Instead of using the stove & risking a nice little fire. You MIGHT try a good heat gun.
Lexan that thin can be molded at around 200deg. Cut the lexan about 2" larger than you need. Build a 2pc frame 1" wide that just slides over the mold with a gap equal to the thicknes of the lexan. Make sure you can trap the lexan between the frame's halves solidly. Thumbscrews work good for this. Heat the lexan until it JUST starts to sag. Then pull it over the mold. Hold it there until it cools. Pull the lexan out of the frame, trim as needed, then install with clear 5min epoxy. This is a cheapskate's vacuum former. If I were a betting man I'd wager that the smallcar kit is vacuformed. If you get this working, you could step up to polycarbonate. It'd cost more for the materials, but it works at slightly higher temps, and would provide a product that surpasses OEM. In lieu of a heat gun, you could suspend the frame in the oven @ 200deg until the lexan sags
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. |
Good on ya man!!! Keep up the good work!! I hope to see something that looks as good, if not better than the Smallcar kit... I got ripped off enough by smallcar, so the last thing I want to do is give them more money...
~ Chris
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
I'd be down for a set, if and when you start cranking 'em out.
-Nate '92 LS-L Pearlie |
wow...it could actually work. can't wait to see the finished product
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
Here's a couple more pics.
Mostly of the bottom and one side that I got finished.
bLAh
For the frame think picture frame with a handle. Cut it from some 1/8" luan (plywood) make 2 squarish frames that are close to the size & shape of the light assy. leave a "handle" on one. Drill holes so you can bolt them together with the lexan between them. This gives your hands a break from the heat.
A quick search on vacuum forming will net you ALL KINDS of ideas.
Lexan is polycarbonate last time I checked.
the message i entered is now long enough
bLAh
