Battery drains overnight.
Does anyone know which fuse supplies power to the sun visor's vanity light?
I put a test light between the negative battery terminal and the body to test for a voltage leak. It shows a pulsing light that goes away after a few seconds. I pulled every fuse and relay from both boxes asside from the airbag fuses, with no change. I also tested any aftermarket equipment. Thanks for any help/advise.
Try searching on "visor broken wire", it might help.
