Old 06-02-2009, 12:56 PM
jamhamm jamhamm is offline
airflow?
how do you get air into this car...?
honestly... its 75 outside and stifling in my svx - even with the windows down...
the vent and econ options just blow hot air around the car...
Old 06-02-2009, 01:05 PM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Re: airflow?
My 96 was like that. I had a hole in my freon line.
Old 06-02-2009, 02:00 PM
Re: airflow?
my ac works fine though
on actual hot days [85+] i pop it on and out comes the cold stuff
im talking about the normal non ac days - its always hotter in the car than it should be because of all the glass and the way the windows are made
would heavy tint on the windows help?
Old 06-02-2009, 02:52 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: airflow?
35% tint should keep a good bit of the UV rays out of the car. You can also crack your windows a couple hours before you get into it and open the sunroof. Also if you want a good bit of airflow when driving without a/c just put the rear windows down, it cools it a good bit.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-02-2009, 03:13 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: airflow?
open the sunroof so the back tilts up
-B
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-02-2009, 04:28 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: airflow?
-B
+1 All I can do since my damn A/C is broken...
Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1˝" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint.
Old 06-02-2009, 04:35 PM
SVXyGirl's Avatar
SVXyGirl SVXyGirl is offline
Re: airflow?
Try having no AC and only one window and the sunroof works. I've been pretty miserable driving the claret lately. (in 90 some degree weather today)
Rebecca
06 Suzuki Boulevard M50 7k
Past SVXs:
96 SVX Bourdeaux LSi (Sold)
Old 06-02-2009, 07:31 PM
PDSides PDSides is offline
Old Guy
Re: airflow?
Lowering the rear windows is critical to getting air circulating in the car. With only the front side windows down you get high pressure buildup in the rear that will effectively keep air out of the car. Lower the rear windows as well and the air flows more effectively. Noise will greatly increase, so if it bothers you try lowing the rear windows only an inch or so. By the way, to more quickly clear hot air from the car, open the sun roof to tilt (or about six inches), then lower the rear windows and drive 30 mph or faster. The hot air will be drawn out the rear windows. Much more effective than lowering only the front side windows.
Preston
Old 06-02-2009, 10:48 PM
PaulDexler PaulDexler is offline
Re: airflow?
The day I collected my SVX from its previous owner in August of 2007, we were in a long heat wave, with temperatures in triple digits all up and down the West coast. It was 103 when I left Solana Beach at noon and launched northward on I-5. A much needed lunch stop put me put me into Oceanside at 1:30, with traffic building up. The P.O. warned me that the A/C did not work, so I lowered all the windows, tilted up the sunroof, and was on my (not so merry) way. Lots of air moved through the car. It was all hot air, but at least it was moving, so long as I was moving. Long stretches of not moving while passing through downtown Los Angeles were unpleasant, to say the least. But I got it home, and the following week the A/C was fixed, and it works to this day. So yes, lower ALL the windows, and tilt the sunroof, and you will at least have air moving through the cabin.
Paul
The great white fleet:
'91 Alfa Romeo 164L 5-speed
'92 Subaru SVX LSL
'93 Mercury (Aussie) Capri
Old 06-03-2009, 12:24 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Re: airflow?
you could also go looking for one of those rear shelf blowers - I got mine from a wrecked SVX (JDM import) here in NZ for NZ$100 including wiring harness & timer module, wiring plug fits between fan relay under glove box - sort of t-junction.
Oh it is "cool" sitting at the lights with windows up & sunroof closed and a 2 speed blower creating a cool breeze behind the ears !!!!
Old 06-03-2009, 08:07 AM
SVX_MY_BABY's Avatar
Re: airflow?
+1 to this with the sun roof open. Works fine for me up to about 90 km/h after which it can get a bit noisy.
Old 06-03-2009, 11:49 AM
SubaruSVXCrazy's Avatar
SubaruSVXCrazy SubaruSVXCrazy is offline
AWD..... NOTHING COMES CLOSE
Send a message via AIM to SubaruSVXCrazy
Re: airflow?
AC is the only way out!
1992 Subaru SVX LS-L #5045 Dark Teal
1992 Subaru Loyale Wagon Gray (SOLD)
1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD)
1969 Subaru 360 Deluxe Ivory White
2005 Subaru Impreza WRX STi World Rally Blue
1993 Subaru Legacy L Wagon Teal Metallic (SOLD)
1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl
[SIGPIC][/SIGPIC]
Old 06-03-2009, 04:57 PM
Re: airflow?
I don't have a/c in my car and by the way the weather has been so far here, doesn't seem like I'll be needing it. There are frost advisories for tonight here I'd really like to know when this global warming is going to actually take affect...
I just usually put all windows down and it feels alright.
Old 06-04-2009, 10:11 PM
Freeman's Avatar
Unregistered User
Re: airflow?
I could use help with getting my drivers side rear window down. Won't budge.
Old 06-05-2009, 09:16 AM
mikecg's Avatar
mikecg mikecg is offline
Send a message via AIM to mikecg Send a message via Yahoo to mikecg
Re: airflow?
I have window tint. I put all 4 windows down and drive really fast.
