AC belt
Is the AC belt removable after releasing the tensioner or do you have to loosen something else? I've released tension but the belt seems too tight to take off. The alt belt came right off.
Both bolts are loose. The idler is freely moving up and down. Right now, the idler is it's highest position where it's not even in contact with the belt. The belt is loose enough to turn back and forth but not loose enough to get the first rib over the lip of the compressor. I tried loosening the compressor bolts and moving it up but that made the belt tighter.
I'm wondering if I have the wrong belt on there to begin with and maybe I should just cut it off and hope that the new belt is larger. I'll go get a new belt before I cut the old one. |
Yes, I would get the new belt before cutting the old one. It should come right off and the new one should go on with no trouble. It could be the wrong belt to begin with.
I've seen them difficult to remove with the tensioner all the way up, figured it was a wrong belt.
One place I got one, Napa maybe???? Had the wrong size in their computer...
I just did a little snooping. The belt on there is Carquest K040330 So I looked up carquest and did a search on the belt and their recommendation is part # k040345. I'll bet that there's a 15mm difference between the two belts. The last guy to replace the belt got the wrong one and had to take the compressor off to get the new belt on. Either that or he had the crankshaft pully off and slid the belt on that way. What a hassle.
I'm still going to get a new belt before I cut the old one off just to be sure. |
I'm sorry, I'm not familiar with the underdrive setup. What's that?
