WTB Power steering Cap or advice
My plastic seal is shot, I dont know if an Oring will fix it from leaking. I would just rather buy a new one, but its NYA. Anyone have a spare or some advice on the seal would be SUPER!
Thanks in advance and my email is bowman262@aol.com which is a lot faster to contact me. Darrell |
Re: WTB Power steering Cap or advice
You can make a seal for the cap out of an old bike tire inner tube. It's just a little circle cut out.
So there IS a seal on the inside of the power steering cap?
What's it look like? A big circle of rubber that covers the whole inside of the cap (with a hole in the middle for the "dipstick")? Mine has no such seal and occasionally ATF leaks out the top of the resevoir. The other day CAM was over at my place and since we were dealing with an unrelated PS leak, he took a look at my cap to see if it matched his (he has also had the problem of leaking fluid out the top). Since both our caps matched, we assumed there was no seal there and it was just a "quirk" of the car. Although I hadn't really noticed a leak until the last year or so, the previous 10 years never had a problem. But I have no idea where the seal would have disappeared to suddenly.
Troy 1992 SVX LSL "Serenity" 250,000 miles! I don't care, I'm still free, You can't take the sky from me... |
The original seal is plastic and fits tightly up against the underside of the cap. IT fits all the way from the center circle to the outer edge. A piece of rubber would work just as well, if not better.
Matt Locker Link 2015 BRZ Limited 6MT 92 Ebony LS-L ECUtune Stage2av1, Z32 MAF, 370cc injectors, TomsSVX intake, BontragerWorks 22mm RSB #003, HID Hi and Lo beams, OT endlink and bushing mods, PWR Aluminum radiator, Harvey's QC shift kit, 2.5" flowmaster 80 exhaust, 17" Michelin Pilot Sport A/S, Poly sway bar bushings, Slotted Bradi rotors, AFBeefcake powdercoated calipers, 97 grill, and a huge set of air horns. 300,000 miles and counting 92 Ebony LS-L. ecutune stage1v4, motorsport 1pc pulley. Garage Queen - sold to Dad in upstate NY 155,000 miles 19 Subaru Ascent Premium - -Hers !. 89 DL 4x4 little red wagon - a.k.a. The immortal suby. 275k R.I.P. Last edited by immortal_suby; 09-06-2011 at 06:58 PM. |
heh, was that picture big enough?
You can use one from any 90's subaru IIRC.
