No start problem OUTBACK
Just got a 1999 limited 30th anni. outback and it won't start. Put a new battery in it and as soon as I turn to start it the clock goes dim and nothing happens. I jumped the starter from the battery and all it does is crank but wont attempt to start. Main concern is why wont the key kick the starter on, I hear the solenoid clicking when I turn it but it just won't go. I'm getting fuel and spark. Any ideas?
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
Re: No start problem OUTBACK
Have you checked the Alternator?
NEW alternator
You obviously have power to the solenoid. Hook the clamp end of your test light to an engine ground then touch the test light to the starter post with the switch in start position. If you get no response to your test light the solenoid contacts are bad. If you get the test light to light you have problems with the starter.
The starters good also. Im just not getting any power to the little connector that goes on the starter.
Auto? Check the connector to the shift indicator, it can be together enough to seem to work, but not enough to pass enough current to the starter.
Manual? Check the clutch switch.
