Option for pedal set for wireclutch.
I just woundring about one thing. I have try to get my Clutch pedal little harder. But whit no luck so far. Are the some one here that have a good solution for that. I cant use the oem spring from the old Legacy that i have take the pedal set from. I used a 1990 Legacy.
Alexander (Norway) My subarus: 1992 Svx LSI 5-MT(3.54) 1998 Legacy BG 2.5L GX |
Re: Option for pedal set for wireclutch.
Are you having problems with the pedal returning? How long ago did you do your swap. I know when I did my swap the pedal stuck but that's cause it was cutting into the wiring brick above the pedal assembly. I used the pedals assembly and brake booster from a '96 Legacy, everything seem to work ok.
Everything must be Modified! |
Nope the pedal is returing. The car is placed inside for the winter.
But i have drive it in the sommer time. And the pedal feel little shoft. I really want it to bee little harder to push. But have you used some spring on the clutch pedal?
hmmm, the only way to correctly change the pedal pressure is to put a stiffer pressure plate on the clutch. I guess you could change the position of the cable on the pedal however that will shorten your throw.
Ok. Thanks alot for the answere.
