ABS accumulator valve relay
Reading a post or 2 I have seen that the ABS valve relay is described as a "usual relay". I have been getting intermittent code 10 so thought I'd change out this relay with a Bosch 30amp 5 prong one...it's a no go..each time I plugged it in, it would blow the 20 amp fuse in the interior kick panel box and I'd hear a little electrical pop when I plugged it in...
Anyone know of a relay other than OEM Subie that doesn't cause this ? Wierd 'cause Manual which shows how to test this relay describes what looks like a typical 5 prong relay?? THX Last edited by fasteract7; 06-19-2013 at 06:56 AM. |
Re: ABS accumulator valve relay/ABS bleeding ???
Testing my Bosch relay and the OEM Matsu**** (pretty funny that it deleted the "sh*ta") shows the 87-87a prongs on the Bosch are in continuity as you would expect but the corresponding OEM prongs are NOT... Another question..some manuals say you can bleed the 2 bleeders on the ABS unit just like the brakes(see below)...pump-open-close..while I have read one description where it says you have to cycle the ABS unit (like on newer units) to bleed the ABS unit. Anyone bleed the ABS unit "conventinally" ??
""BLEEDING BRAKE SYSTEM NOTE: Use FMVSS No. 116, fresh DOT 3 or 4, brake fluid only. Ensure brake fluid reserve tank never becomes empty. Check all brake system lines and connections for leaks. ABS BLEEDING PROCEDURES 1) Using conventional manual brake bleeding method (using vinyl tubing and container, with foot pressure on brake pedal), follow sequence in BRAKELINE BLEEDING SEQUENCE table. See Fig. 3 or 4. 2) Attach one end of tubing to bleeder screw and place other end into container. Have assistant depress and hold pressure on brake pedal. Open bleeder screw 1-2 seconds and then close it. Release pressure on brake pedal. Repeat procedure until air has been discharged from system. See BRAKELINE BLEEDING SEQUENCE table. Bleed each caliper until air bubbles stop appearing from bleeder tubing in fluid bottle. Close bleeder screw. ABS system bleeding is completed. 3) When air has been removed from all six connections, depress brake pedal using about 66 lbs. (30 kg) force and hold it for about 20 seconds. Check pedal for any unusual movement. Install wheels. Test drive car for 1-2 miles, ensuring proper operation of brakes and ABS system. BRAKELINE BLEEDING SEQUENCE TABLE Application Sequence Legacy ......................... (1) HS, RF, LR, (1) HP, LF, RR SVX ............................ (1) HP, (1) HS, RF, LR, LF, RR (1) - HP (hydraulic unit primary bleeder between LF and RR); HS (hydraulic unit secondary bleeder between RF and LR). "" Last edited by fasteract7; 06-19-2013 at 07:27 AM. |
