Does a 9005 bulb reverse harness socket exist???
OK, to clarify... the car plugs directly onto the 9005 bulb. I need a wire socket that is like the BULB side, so that I can plug into the car harness at that point.
(I am making a custom harness for my german bulbs...) The german lights use h3 for the highbeams. We use h3 for the foglights. Now, for those who know what the foglight harness looks like on the lamp housing side, you have the bulb cover, with the wires going thru it. You have 2 flat blade connectors for the bulb inside, and a harness plug on the outside. b/c I have h3 highbeams, I need to have 2 flat connectors (easily made) on the inside, and a 9005 socket on the outside. They must exist for things like 9005 HID retrofits. I did a look around any didnt find any...
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN! |
Re: Does a 9005 bulb reverse harness socket exist???
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 Last edited by Green1995SVX; 04-13-2009 at 05:03 PM. |
I love you.
They actually came out quite well. When you dremmel away the old housing you're left with a nice blade for a connector. Solder it on, heat shrink it and voila. Now I'll leave you two alone.
If you're cheap like me you can get out the dremmel and 4 burnt bulbs and go to town. If I had to do it again I'd go with those.
I am poor, but not cheap.
Nah, I've been in your position before (like with my broken foglight housing...), but when I can, I try to go as professional as possible... even if I have to wait. But THIS time.... harness is on the way.
