Old 01-02-2009, 10:54 PM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
Question Hot Air in footwell and from under ashtray
Hi all,
I have searched the forum looking for an answer to this question.
Does everybody's SVX emit a LOT of heat around the footwell and from under the centre console? I got some coins out of the ashtray before and they were HOT!!!
Is this the infamous heat generating from the 4EAT?
I have just installed a new 5 pass aluminium radiator and front mounted transmission cooler - should they lower the temp I am feeling?
Mike
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 01-02-2009, 11:33 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Hot Air in footwell and from under ashtray
One thing ive noticed about the SVX climate controls is that they stay in whatever position they were in before being turned off. If I had my heater on at one point, the climate controls will allow fresh heated air blow into the footwell even when the system is turned off. Im not sure if this applies, but if you push "Circ" after you start the car, it will block the fresh air from blowing through your heater core into the cabin. You can also set the system for the lowest temp (I think 65') before turning the system off, which will route the air around the heater core and just let in fresh cool air while you drive. Worth a try before suspecting the trans.
Old 01-03-2009, 12:51 AM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
Originally Posted by BRADY View Post
Hi all,
Mike
I always have heat coming from that area but I only really notice it in the summer.
