Launch Control with Hydra EMS
I didn't want to post in the hydra thread as this is an add on feature, and not currently something they are working on. I wanted to see though if it was something some people are interested in, especially once some of us end up turboing.
Tom, is it possible to offer this as an option? how hard would it be to set up? is it something we can just set up the button and order the cable from hydra and just set it on our own or is it more complex?? |
Re: Launch Control with Hydra EMS
Its really simple. Basically you need to wire a switch to a couple of the aux inputs on the hydra harness. That switch will basically complete the circuit to power or grnd, Your choice, and enable the traction control which you need to setup. The setup is simple... Take the car out and give it you best shot on dry pavement. Take note of the highest change in vehicle speed (AKA vehicle speed delta). Then get on some gravel or sand and make the tires break loose. and note the delta. You would want your traction control delta somewhere in between. Then you can write a map for how much fuel or timing you want the ECU to pull when you cross the threshold, which will in essence create your traction control. Once you cross back over the threshold into normal delta the normal timing and fuel maps will be reinstated
Tom |
Is this something that will add any significant benefit?
Depends. More or less is it is a nice feature but if you know how to drive the car properly, you will never need it
Tom |
Launch control just helps with consistency on launch and helps with a more powerful launch, basically letting a computer control your rev limits for best performance on launch. But, all in all like tom said it's not needed if you can drive the car well. It's more of something to help get your 1/4 times down just slightly. It's kinda like a racing luxury feature. lot of wrxers and evo guys use them.
would the map be supplementary to the original map or would I have to modify the base map?
