Help!...Brake lights don't work
So, my rear lights are always on...the lights that are supposed to come on with your headlights. In addition, when I hit the brake, they do not change intensity. This is post 5MT swap. Did I forget to reconnect something? Help is greatly appreciated as I would like to wrap up this 5MT swap. Thanks!
Mat
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
You didn't do something silly like hit the parking light button did you?
Is there an adjustment for the switch on the brake assembly? I know some older vehicles suffered from this malady. Did you forget to re-plug a connection after installing the pedal assembly? Good Luck, Dan |
Thanks
Hey fellas. Thanks for the input. Not sure exactly what the problem was, but I got rid of it simply by removing the brake light switch and re-installing it. All is well now.
Mat
Doubtful...I used the same one when I put it back in I was completely baffled. Whatever...it works now
