Adjusting Idle RPM?
Does anyone know how to adjust idling RPM? Mine seems bit low and I'd like to increase up to 600 or 700rpm. Is it easy or gotta get some new parts??
Thanks.
-Ryu Links: 2004 Honda S2000 (2008~) 1992 Subaru SVX LSL Liquid Silver (2007~2008) 1996 SVX LSi Bordeaux Pearl (2006~) 2002 Lexus IS300 Sportcross (2005~) 1992 Subaru SVX LSL Pearl White (2001~2005) 1994 Mercury Sable GS (1999~2001) 1/43 Scale SVX Models [SIGPIC][/SIGPIC] |
Ryu
When you say it's low, I must presume less than 600 rpm. If it is not causing the car to cut out, why would you want to up it? Or is the car cutting out? Joe
One more thing.. when A/C is on, RPM is slightly higher, so no problem...but I'd prefer fresh summer breathe from window you know...
The RPM is supposed to be higher to account for the A/C being on. That's normal. On the EJ22 (the engine in the Legacy), there's an idle adjustment screw located right where the throttle body meets the intake. I'm pretty sure there is one in the SVX located in a similar place. tightening the screw should raise the RPM slightly. You might also want to consider cleaning the Idle Air Control Valve.
it would be new to me. As far as I know (and what is stated on the underhood label) the EG33 idle is not adjustable. It does go up with the AC on, but AFAIK you can't adjust it. You could adjust your throttle cable linkage to raise it up.
I'll check the service manual to see if I can find something that says otherwise. LAN could most likely tell us if it is something in the ECU or in the IAC that sets where it will be.
