stereo head unit install - instrument panel??
I know I saw this exact issue a week or so ago but searching didn't seem to yeild anything. I just installed a new stereo head unit in place of one that was stolen. Now, some of my gauges don't light up (speedo, tach, enviro buttons), but thanks to a loose connection to one of my brake lights, i know that the trouble indicator lights still work. I didn't alter any wiring except for cutting the old into-head harness off and splicing the new harness straight in. I seem to remember the solution having something to do with the ground wire, but I could be wrong. Any ideas?
Kevin Crutchfield Neophyte SVXer 92 LS-L Ebony/Lqd. Silver, stock, 88xxx miles, flung into a telephone pole by a drunk a month after buying 92 LS-L midnight black 141xxx miles, WRX FPR, MAF bypass, lightened underdrive pulley, formerly AppstateSVX's |
http://www.subaru-svx.net/forum/show...ghlight=ground .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 01-06-2007 at 08:00 PM. |
I looked at that thread to double-check, but that seems to be a totally different issue. If the ground plate wasn't in contact with my bracket, I'd have no sound. The stereo works perfectly. It's probably not a burnt out bulb - if it were, the needles at least would still be lighting up. I've checked the fuses and none of the possible suspects appear blown. If there IS a fuse at fault, I'm pretty sure it's got to be the #9 10 amp fuse in the cabin fusebox. Feel free to correct me, anybody. I'm going later to pick up a replacement just in case, but I'm really stumped on this one.
Kevin Crutchfield Neophyte SVXer 92 LS-L Ebony/Lqd. Silver, stock, 88xxx miles, flung into a telephone pole by a drunk a month after buying 92 LS-L midnight black 141xxx miles, WRX FPR, MAF bypass, lightened underdrive pulley, formerly AppstateSVX's Last edited by craftylandshark; 01-07-2007 at 11:53 AM. |
fixed... the fuse was the bugger. very strange though, the wire looked completely intact from both sides of the fuse... definitely did NOT appear blown. bizzare.
People usually have problems with there being two Red / Black wires. For anyone else who runs across this thread... For Sale: Radio Wiring Harnesses for SVX!!
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
The previous owner had already done a cut-and-splice, so at that point, i figured i might as well do the same thing. It worked out fine, no issues with two red and black wires. Meh, who knows.
