common problem?
Just a few questions to ask,
was wondering if the valve cover gaskets leaking are a common problem. Mine seem to have a small leak. Also when i turn on my headlight, on the dash lights you can see a pulsing, bright then dim, bright then dim, under the impression that it is the alternator, the alternator is less then 10k old from last owner Also while I am here something weird happened today, started the car, rpms went to 500 and wouldnt go higher, soon as i touched the gas the car would stall....did this a few times and finally i let it sit at 500rpms for a little while and pressed the gas and it didnt stall, acted weak but didnt stall. any ideas would be appreciated. thanks all Jerad |
Just saying hi to a fellow, Syracusean
yes valve cover gaskets are a common problem... it sounds almost like the replacement alternator isn't rated at high enough amps... so when you have a full electical load on the car it is straning... i would go in and get a quick electircal test. as for the stall... unless it happens again i wouldnt worry about it
Do you have any engine codes?
yeah check engine code came on this morning, did the same thing this morning and this afternoon when i got out of work, once engine is to temp i can shut it off and it comes right back on,
think it be the temp sensor? thanks jerad |
Have your alternator tested at an alternator shop. It might still be bad, thats what was wrong when my lights were pulsing. After replacing it, it totally went away, and seemed to run better in general.
yeah I've got leaky valve cover gaskets and light problems too.. The gaskets I don't care too much about, I haven't had an oil change since like January (2800 miles ago) and am still just below F on the dipstick. The oil is still nice and clear too (Mobile 1 syntec = best oil ever). I've read a bad voltage regulator causes the lights to do that but I haven't replaced that yet either.
Brian |
Most times on subarus its just a matter or tightening (properly) the screws on the valve covers. Dont over tighten them as you will make it worse.
nipper |
thanks for the help
checked the code, was a coolant temp sensor, gonna have to find out where that little bugger is and replace it tomorrow thanks jerad |
