Alignment specs for the SVX
Looking for someone with a service manual to post the alignment specs for an awd SVX - camber, caster & toe. I scheduled an appointment today with my local tire shop to have a 4 wheel alignment done on Friday morning at 8am.
Thanks! -Chike
SVX
Camber (1) Front ................... -0.42 ............ -1.17 To 0.33 Rear .................... -0.67 ............ -1.42 To 0.08 Caster (1) ............... 4.83 .............. 4.08 To 5.58 Toe-In (2) Front ................... 0 (0) ............ -0.12 To 0.12 (-3 To 3) Rear ................... 0 (0) ............. -0.12 To 0.12 (-3 To 3) Toe-In (1) Front ..................... 0 .............. -0.24 To 0.24 Rear ...................... 0 .............. -0.24 To 0.24 |
Thanks for the quick response! I was talking with Svxfiles tonight and he mentioned that you definitely want to make sure they zero-out toe front & rear on an awd car. The above factory specs confirm that...
My rear passenger-side tire seems to have a good deal of toe-in which is causing the plastic cover in my wheel housing to rub aginst the inside of that tire in sharp left hand turns. Luckily the rubbing isn't that bad, and I should be able to make it to the Fall before needing to replace this set of summer tires. -Chike
You could try to get a little extra grip in the front by making the front wheel camber a little more negative than the rear wheels. BTW, do you have camber bolts installed at the rear?
Chike,
The front will handle up to -1.5 degrees of camber with the stock bolts. As Mychailo has noted, you'll have to add aftermarket camber bolts to get any camber adjustment in the rear. Zero toe front and rear is a good for straightline stability and helps keep tire wear to a minimum. -Bill
No camber bolts installed on the rear at this time. Due to unexpected expenses of replacing both rear wheel bearings, a transmission and buying a house, it doesn't look like I'll be autoXing my car this season - only drag racing. -Chike P.S. I'll have them dial in some extra -ve camber in the front (probably -1.0??) and zero out the toe front & rear. Thanks for the input guys! :-)
The aftermarket camber bolts are very inexpensive. Should be able to find a set for less than $30.
If you drive insanely around the corners go with more negative camber and more caster. That will give you better grip in the corners and prevent you from rolling onto the sidewall. Of course, more negative caster will wear out the inside tread faster if you do a lot of highway driving. I need to get an alignment myself soon. If the car can handle -1.5 with the stock bolts, that's what I'm going to do. -Matt |
Yes, the front bolts will provide -1.5 degrees of camber
Yes, definitely go to a shop that has an experienced alignment mechanic - I actually found one that is a true artist - he adjusts each wheel separately and actually goes back and forth between the front and rear wheels to make sure everything is perfect (camber, caster, and toe). When I first started autocrossing I tried going to a local tire place and had no idea how bad a job they had done until I took the car to the guy I use now and he showed me what the "before" setting were (example = -1.0 degrees of camber was -1.2 on one wheel and +.2 degrees on the other!!). -Bill
Since the back won't come around at all maybe we can get the front to come up to speed.
