Old 12-21-2006, 01:06 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
So it only whines with rpms and not necessarily speed? Does it do it in every gear including park and neutral?
Brian
Old 01-19-2007, 10:18 PM
KWBum KWBum is offline
Well, well...
I called it a "buzz" in my post but your description of "whining," or maybe "whirring," sounds just like my problem on my '92 SVX.
It gets louder with higher RPMs.
I suspected the transmission, as it momentarily diminishes at the shift points. I tried some additive, and it didn't do a darn thing.
I have no idea, but it may well be the exhaust. I dunno. The SVX, with that huge muffler, does not sound like any other car. Or like a car at all. More like an electric golf cart.
It's going into the shop next week. We'll see if he finds anything...
Old 01-20-2007, 10:35 AM
what a great thread. i've developed a whine over the past couple of years and now my svx won't even start. i have a battery charger for the camper which i tried to use on the svx last week. it said my battery was good and wouldn't turn over with just the charger connected. starts just fine with connected to another car with jumper cables. at first, i thought it was the battery because after driving for some time, it would start up again no problem. but last week, the instrumentation seemed noticeably dimmer and after letting the car sit for only an hour or so, it wouldn't start again and required another jump. when i got home after a 45 minute drive, i turned the car off in the garage and it wouldn't start. i'm not pretty sure my alternator is shot and when i get it fixed, my whine will go away.
Old 01-20-2007, 03:47 PM
Originally Posted by Karl
hmmmm yes...sounds like you need to replace your muffler bearing:
There actually is a gasket called a muffler bearing on the SVX... But I doubt that is causing the whine... PS all the way. Check ur fluid level
Old 01-20-2007, 03:49 PM
wait.. it went away after you took out your Ipod?? Try shutting off the radio in the car all together and it should go away... This is a typical symtom after someone has installed an after market head unit... The is a lack of ground and the speakers actually play by the RPM of the car... Shut the radio off and see if it goes away
Old 01-20-2007, 10:24 PM
Crysis Crysis is offline
AK Rowdy
Send a message via AIM to Crysis
I have that same ipod adapter and it causes a "whining" noise out from the speakers when its paused and it gets higher pitched the more I press on the gas.
Old 01-20-2007, 11:27 PM
Welcome to the world of aviation and our shielded spark plugs.
It is possible for the current running through the ignition system to cause interferance with the audio system, I've heard it in planes with poor shielding. Cars have more sophisticated ignition systems and that generally takes care of interferance, but it is possible.
Going out on a limb: If it has to do with the iPod, is it possible that the iPod cable itself is acting as an antenna, picking up and amplifying the interferance?
Old 01-21-2007, 04:01 PM
craftylandshark craftylandshark is offline
<edit> never mind, everyone beat me to it lol... I've had the iPod tape adapter whine on two different cars, including my first SVX with the stock head unit. Cleaning the tape deck heads helped a little bit I think... might have just been psychosomatic though.
Kevin Crutchfield
Neophyte SVXer
92 LS-L Ebony/Lqd. Silver, stock, 88xxx miles, flung into a telephone pole by a drunk a month after buying
92 LS-L midnight black 141xxx miles, WRX FPR, MAF bypass, lightened underdrive pulley, formerly AppstateSVX's
Old 01-21-2007, 11:47 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
my guess its inside the trans...
Ive heard similar noises on several svxs...
some did it for over a yr with no problems...
but others....where like a time bomb
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 01-22-2007, 08:29 AM
The Goat The Goat is offline
My wife used to whine when I romped on my SVX....
Old 10-10-2009, 02:47 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
Re: whining sound when i press on gas
my car started a whine like this...and no its not the radio...i had the radio off.
im scared to drive my car casue i dont want it lock up on me or something....ughh
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
