Twin turbo TD04-13T project: Journey to 300+whp
This thread will be dedicated to my EG33 swapped 01 legacy, with the goal of 300-350whp through a phase 2 4eat. In addition to this thread, you can follow me on rs25.com "link" OR over on www.youtube.com/subimodz . I'll be updating both places but I don't journey here as often as rs or youtube for my updates.
Things I have: Spare eg33 Spare exh headers TD04-13T Things I need: One TD04-13T's AEM Fic6 (got a quote, just needs ordered) Walbro 225 (quoted, needs ordered) 420cc oem WRX injectors (8 for 180$ shipped) I'm also going to be getting an ST coilover set here soon, so the turbo build will be a slow gathering of parts as $$$ becomes available. I'm also going to get my ass in school, so funds will be limited but, this build wont be like others. I'm not going to make a thread and update it for 10yrs. ****s gonna get real, really real. Last edited by BackWoodsBob; 08-09-2013 at 11:41 AM. |
Re: Twin turbo TD04-13T project: Journey to 300+whp
Just a few pics from the initial swap last year.
My overall plan for where and how to mount the turbos are as follows.
2 turbos, either mounted directly to, or just off of each exhaust header. Twin front mounted intercoolers to a normally mounted intake manifold. If I get myself aluminum welding gear I'll flip the intake manifold. I'll be dropping my radiator about 2 inches to make room for the intake tubes. I also need to plate off the radiator cap and install a steel bracket to the OE rad crossmember. |
Just confirming, you ARE planning on doing full internals, correct?
How about oil return? The manifold exits are very low, much lower than the oil level in the pan.
See "from below" photo here: http://www.subaru-svx.net/forum/showthread.php?t=61945 /T |
nope. 8psi to start and sate my appetite as I rebuild my spare block with Manley hrods. stock, shaved pistons and cams. :-)
I was just double checking for your 300whp goal. Because you will blow ringlands as you approach that number on a stock engine. That's all
You can't stay with stock pistons to reach what you are trying for. The stock pistons are much weaker than the stock rods, and it is a waste of money to upgrade the rods and stay with the stock cast pistons. You could use stock rods and forged pistons, or upgrade both, but the pistons are the weak point in almost every Subaru motor ever built when you add boost.
