Uh oh - Dash Board Lights Flickering. . .
Okay - a couple months ago I replaced the alternator in my '92 svx. no problem - issue fixed, but today I put my foot on the brakes and noticed that the battery light, brake light, and another "stop" light on the dash started to flicker. Not just flicker, but every time I put my foot on the brakes they flicker, when I hit the gas they flicker, when I turn, when the tranny shifts they flicker. My initial thought was that the alternator was going bad. But has anyone else had any similar issues? My second thought is a short in the electrical system or the transmission sterting to go kaploot. Need help - any input would be appreciated. . .
Re: Uh oh - Dash Board Lights Flickering. . .
You could try removing/adding the wire ground mod, depending on what you have now. I would highly suggest that you buy a voltmeter, though. They're pretty cheap — maybe $10 - 15. Test the voltage on your battery when the car is off. It should read 12 - 12.5 volts. Anything less, and your battery is probably bad. Test your battery with the car on, and it should read 14 - 14.5 volts from the alternator charging it. Anything less, and your alternator has a bad hookup, your alternator is shot, or maybe your battery and alternator are shot. Something that someone just told me recently is that batteries and alternators often die as a pair. The battery starts to lose its juice, so the alternator has to work near its full capacity in order to keep the battery charged. Unfortunately, alternators can't work at full capacity for very long. So, you replace your alternator, but it dies again soon because the battery is still losing juice. Either that, or you replace your battery, and it dies again soon because the alternator is on its way out. Then you're back to square-one, cause your alternator is still on its way out. Anyway, point being, you need to make sure your battery is ok before you do anymore driving on that new alternator. Even though it's new, it could die from trying to keep a bad battery charged. |
Check the belt tension for your alternator as well. Just push on the most spacious part of it with your finger. When pushing with moderate force, you should only have 0.25 - 0.5 inches of play.
Did you get a new belt when you got the new alternator? I would definitely suggest doing that as well. If you did, you should recheck the tension, as they tend to stretch a little. |
Thanks for the Input
Well guys, thanks for the input. . . I think I found out what it is though, the alternator took another dump on me this morning. I got up early this morning to check my belts, etc. Event tightened the belt just to be sure that wasn't it. The car started fin, but by the time I got to work the battery was dead as a door nail. So, I called the company I bought it from and they are overnighting me another one - no questions asked. I checked the voltage on the battery (as it is a pretty new battery of less than a year). But what can you do. Another svx story told. But again - I appreciate the input.
Re: Thanks for the Input
Search under x-mas lights. Replace alternator.
x-mas lights and more
Yeah, I think the official plan is to replace the alternator, battery and the poitive and negative lines from the battery to the ground and the starter. I'll bet they have never once been replaced and with 232,000 miles closing in - there's not a better time.
Alternator Replaced
That is what I love about the SVX - Alternator replacement from Fedex delivery - 1 day - actuall replacement time18 minutes from dead to engine startup. Love it. New battery - on the way . . . . .
I have the same problem going on. I had my alternator checked while it was on the car and they said it was pulling 13.7 v. This is a low reading and I am assuming the voltage regulator in the alternator is bad. I took my ac belt off, put a new belt on the alternator, ran it around ten miles and the lights never came on once. Put new ac belt on, the ligts came back, even with good tension.
If a diode in the rectifier bank is shot, alternating current can be induced on line and this will bypass blocking diodes within the fault light circuit. This type of fault is regularly missed, because there may be only a small reduction in the total output voltage. Switch the meter to an AC range and if any voltage is detected, the fault is disclosed.
So I have still been driving on the same alternator, the lights on the dash still come on and go off sporadically. I have checked the voltage recently and alternator is charging and pulling about 14.5 v constant. With ac wide open, stereo blasting(with amp and subs), lights on bright, and cooling fans running, voltage only drops down to 13.5 but soon charges right back up to 14.5. Battery is showing good as well. Still cant seem to figure why all the lights illuminate?
well, this is in response to alternator lights illuminating at random. Its been a little over a year and I just replaced the alternator. The other one didn't go out, I just came across Maniac Electric Motors, who does an awesome job with alternators by the way, and couldn't pass up the deal. http://www.maniacelectricmotors.com Anyhow, no more lights illuminating! The car actually seems to run better.
