Step on gas and car hesitates?
Ok another issue with my car, and i just want to confirm my conclusion or to get an answer to what is broken on my car. From a stop i start to accelerate and the car hesitates for a second then speeds up. It is also noticable after the acceleration and driving at lower speeds. I think this is a bad maf (judging from my other idle issue problem) or it is time to change my spark plugs. They haven't been change in a long time. I've been getting horrible about 260 miles per gas tank on a good day (highway and city driving, short distances). Can these simptoms all be related to maf and spark??
Thanks for the help guys |
yea i would change the spark plugs if i were you
spark plugs made no difference for me as i have this same problem...but only when my a/c is running....check the maf
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
if your other problem is a low idle stall then you should also check between the maf and throtle body for leaks. I saw one with this problem and the cause ended up being the driver side tube was folded over making it hard to start or drop to idle without dying.
It created a source for the engine to suck unmetered air in and therefore did not provide enough fuel. Hope that helps a little.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
the idle is jsut speratic, it can jump from 700 to 2000. If i restart the car it kinda brings it back down to normal. I've posted a tread about this one before but didn't get it resolved. I'm just wonder if all these symptoms are for the same thing.
My black '92 also 'bogs' severely when I accelerate from a stop. The bogging is making left turns through traffic downright dangerous. I'm not yet entirely sure of the cause of the problem, but I'm going to start by replacing a bad O2 sensor
(on order) and go from there. If that solves the problem, then great, but if not, I'll have to start considering the throttle position sensor and the MAF. I'm also due for a spark plug replacement, but I don't think that bad plugs are the cause of my problem. I also have some occassional variation in idle speed, usually between 300-1000 rpm. It doesn't happen very often, and it only happens when I put the car in 'park' after driving.
1992 LS-L Touring, Ebony Mica, 177k kms. Bead crush complete! Needs some bodywork & interior bits. Gold OE-style rims , Sony deck . For sale or trade 1992 LS-L Touring, Liquid Silver, 106k mi. "Alice." Brand-rebuilt title. Mods: WRX 6-CD changer, 16" Rage Vigor, PWR rad, Perrin LCP, JDM v.8 6MT. |
