OBDDII code P0106
Anyone ever fight one of these beasts. I have it in the dealer trying to track it down and it has been very elusive so far. I tried finding a specialist around Boston but had no luck. The car runs well at speed but idles poorly and has the CEL. This car has new catalytic converters, oxygen sensors, knock valve, PCV all a couple thousand miles ago and now MAF. Just had the plugs changed as well.
Thank you |
Re: OBDDII code P0106
Check all vacuum hoses closely for hairline cracks? I also read once that someone had the main air intake hose come loose.
